RV.Net Open Roads Forum: Tech Issues: 170VAC coming from my Onan generator
 > 170VAC coming from my Onan generator
SHRED
Encinitas, California
Posted: 02/19/21 09:15am Link  |  Quote  |  Print  |  Notify Moderator
It's a 1995 4000 BGE.
I posted earlier but wanted to focus in on this problem.
I tested the lead coming into the breaker switch and it was a consistent 170 VAC.
What should I check next and how?
Regulator?
Thanks
1995 Lazy Daze 23.5' TK
Gjac
Milford, CT
Posted: 02/19/21 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Does your genset seem like it is running at a higher rpm than normal? You can buy cheap HZ meter plug it into your 120 v socket and adjust the speed to read the correct HZ at the proper rpm.
enblethen
Moses Lake, WA
Governor! Does the genset sound like it is running overly fast?
If you can see and get to the throttle linkage see if it is moving.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Dusty R
Charlotte Michigan 48813
Posted: 02/19/21 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Look and see what the output voltage is supposed to be. At that voltage it is also running at 60 HZ, this has to do with the building of the generator.
So using a decent volt meter will do.
If there is an adjustment on the governor I would try slowing the engine down while watching the output voltage, setting it at or a whisker over.
Jetstreamer
Milwaukee, Wisconsin
Posted: 02/19/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Check the batteries and verify your meter is reading correctly by checking voltage from home source.
Just saying cause I had this happen to me once.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 02/19/21 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
You need to seek and record the MODEL and the SERIAL NUMBER of your generator then post it. Some generators are volts per Hertz (speed sensitive)
And DO NOT TRUST a critical finding like this to a single measuring instrument.
SHRED
Posted: 02/19/21 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
MODEL: 4BGEFA26100M
SERIAL: D953355775
dougrainer
Carrolton, Texas
Posted: 02/19/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
AC Output
Voltage Too Low
Or Too High
Noisy Generator
Possible Cause
1. Open circuit breaker
2. Open circuit between brush
block an CR4 rectifier
3. Brushes stuck in holder or
not making good contact with
slip rings
4. Defective CR4 bridge
rectifier
5. Open, grounded, or short
circuit in rotor, stator, or
transformer
1. Engine governor incorrectly
adjusted
'2. Open diode in CR4 bridge
rectifier
*3. Brushes worn or not making
good contact with slip
rings
4. If generator frequency is
within specified limits but
voltage is incorrect,
transformer is incorrectly
connected or defective.
'5. Open, grounded, or short
or transformer
'causes low AC output voltage
1. Loose brush holder
2. Worn generator end bearing
3. Rotor and stator rubbing
together due to: a) varnish
lumps, orb) rotor
misaligned with crankshaft
Corrective Action
1. Locate cause of overload
and correct as required.
Reset breaker
2. Check for continuity and
correct if circuit is open
3. Release brushes if jammed
in holder. Clean slip
rings if dirty.
4. Test rectifier and replace
if defective
5. Test each component for
open, grounded, or shorted
windings and replace if
defective.
1.
2.
3.
5.
Refer to Governor
section
Test CR4 rectifier and
replace if defective
Check length of brushes
and replace if worn
excessively. Clean or
replace slip rings.
Adjust tap connections on
transformer secondary
windings to obtain correct
voltage. Replace
transformer if voltage cannot
be corrected with adjustments.
defective.
SHRED
Posted: 02/19/21 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
AC Output
Voltage Too Low
Or Too High
Noisy Generator
Possible Cause
slip rings
rectifier
transformer
adjusted
rectifier
rings
or transformer
lumps, orb) rotor
Corrective Action
Reset breaker
rings if dirty.
if defective
defective.
1.
2.
3.
5.
Refer to Governor
section
and replace if worn
replace slip rings.
voltage. Replace
defective.
I didn't see "regulator" in there.
I'm getting to the point where professionals need to look at this mess I think.
I did unhook the ATSwitch and the breaker on the genset didn't trip off which was my original symptom.
Now I'm thinking the high voltage may have damaged the ATS.
* This post was edited 02/19/21 03:52pm by SHRED *
time2roll
Posted: 02/19/21 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Might interchange the word governor since it regulates engine speed.
adjusted
Yes get it in to a pro for best results.
675w Solar pictures back up
