RV.Net Open Roads Forum: Tech Issues: 170VAC coming from my Onan generator
 > 170VAC coming from my Onan generator
Page of 5
3 tons
NV.
Posted: 02/20/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Note that 170v is standard AC sinusoidal ‘peak’ voltage that relates to 120v which is RMS... Perhaps check your instrument settings...
3 tons
enblethen
Moses Lake, WA
Posted: 02/20/21 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Voltage regulator located behind start/stop panel
Parts manual See pages 46-47
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
SHRED
California
Posted: 02/20/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the great advice. I wish there were "like" buttons for posts. You all are great.
I am also contacting Flight Systems soon.
2021 27' Lazy Daze mid bath
enblethen
Moses Lake, WA
Posted: 02/20/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Flight Systems was easy to work with!
poppa
Dallas, TX
Posted: 02/21/21 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
what? no light bulb for a meter? maybe a true rms meter?
enblethen
Moses Lake, WA
Posted: 02/21/21 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Light bulbs with tungsten filaments are a thing of the past.
Nasty when high voltages popped them and broke the glass.
What did work but hard to find is neon light bulbs.
SHRED
California
Posted: 02/23/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
UPDATE
I followed this video for testing.
MEASURING YOUR GENERATOR WINDINGS
I then called Flight Systems with the results.
They are so helpful.
Pins 9 and 10 test was not good.
I've got new brushes and springs coming plus I need to shine up the rings.
Chances are my regulator is damaged they said by the fluctuations from the brushes not making good contact.
That video is very helpful.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 02/23/21 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Hint: Use only FLINT PAPER on slip rings. Other materials embed abrasive particles in the copper wildly accelerating graphite brush deterioration. Brush contact to chassis ground resistance should not affect a 30 megohm reading. Disconnected from load the same is true for stator lead tests.
enblethen
Moses Lake, WA
Posted: 02/23/21 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Fight Systems sends a tool to clean slip rings
SHRED
California
Posted: 02/23/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
I ordered it.
It'll be here Friday.
Page of 5
