3 tons
NV.
Note that 170v is standard AC sinusoidal ‘peak’ voltage that relates to 120v which is RMS... Perhaps check your instrument settings...
3 tons
enblethen
Moses Lake, WA
Voltage regulator located behind start/stop panel
Parts manual See pages 46-47
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
SHRED
Encinitas, California
Thank you all for the great advice. I wish there were "like" buttons for posts. You all are great.
I am also contacting Flight Systems soon.
1995 Lazy Daze 23.5' TK
enblethen
Moses Lake, WA
Flight Systems was easy to work with!
poppa
Dallas, TX
3 tons wrote: Note that 170v is standard AC sinusoidal ‘peak’ voltage that relates to 120v which is RMS... Perhaps check your instrument settings...
3 tons what? no light bulb for a meter? maybe a true rms meter?
enblethen
Moses Lake, WA
Light bulbs with tungsten filaments are a thing of the past.
Nasty when high voltages popped them and broke the glass.
What did work but hard to find is neon light bulbs.
SHRED
UPDATE
I followed this video for testing.
MEASURING YOUR GENERATOR WINDINGS
I then called Flight Systems with the results.
They are so helpful.
Pins 9 and 10 test was not good.
I've got new brushes and springs coming plus I need to shine up the rings.
Chances are my regulator is damaged they said by the fluctuations from the brushes not making good contact.
That video is very helpful.
MEXICOWANDERER
las peñas, michoacan, mexico
Hint: Use only FLINT PAPER on slip rings. Other materials embed abrasive particles in the copper wildly accelerating graphite brush deterioration. Brush contact to chassis ground resistance should not affect a 30 megohm reading. Disconnected from load the same is true for stator lead tests.
enblethen
Moses Lake, WA
Fight Systems sends a tool to clean slip rings
SHRED
enblethen wrote: Fight Systems sends a tool to clean slip rings
I ordered it.
It'll be here Friday.
