adamis
Northern California
Been doing a lot of research in my preparation for buying a fifth wheel. One of the things that has surprised me is the use of the 5th wheel over a gooseneck design. Considering the weight and space taken in the bed of the truck, why aren't goosenecks a standard in the first place?
For my own needs, I already have a gooseneck ball in my truck so I'll be doing the Reese Goosebox from the start as it seems to be the best option out there. Just curious if there was a solid explanation on why the industry went one direction versus the other...
1999 F350 Dually with 7.3 Diesel
2000 Bigfoot 10.6 Camper
schlep1967
Harrisburg, PA
My guess would be easier hook-up. With a 5th wheel you have about a 10 inch wedge you need to fit a 3 inch pin into. With the goose you need to get the things ligned up almost perfectly to lower it onto the ball.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
dieseltruckdriver
Black Hills of SD
It is due to the frame stresses. Look at how heavily built your goose neck trailers are up front. It would cost too much to build an RV that heavy.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
BB_TX
McKinney, Texas
I agree with both of above. Easier hookup since it is self aligning side to side and stops and self latches when the pin is all the way inserted. And no safety chains required.
And the manufacturers don’t have to build the frame as structurally strong, meaning less expensive. Broken frame welds is not uncommon even with a 5th wheel hitch. That is why some manufacturers say they will void the warranty if you use a gooseneck adapter.
Walaby
Georgia
Reese Goosebox weighs about 225lbs. My Pullrite Superglide weighs nearly 300, but I know other 5th wheel hitches weigh less than 300, so weight difference is probably overall minimal. Of course, if Goosebox REPLACES existing pinbox (which Im guessing it does), then weight differential is greater.
I believe the Reese Goosebox is the only gooseneck that Lippert will not void the warranty if you use.
Ease of hookup is another Im sure, but how much harder is it to hook up a gooseneck than it is to hook up a bumper pull TT?
In terms of why INDUSTRY went this way, Im sure it had to do with the frame stresses and the ability for manufacturers to use cheaper pin boxes, and not have to worry about compatibility. If a buyer wants a different pinbox, they will ask for it and pay for it accordingly.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Old-Biscuit
Verde Valley
Walaby wrote: Reese Goosebox weighs about 225lbs. My Pullrite Superglide weighs nearly 300, but I know other 5th wheel hitches weigh less than 300, so weight difference is probably overall minimal. Of course, if Goosebox REPLACES existing pinbox (which Im guessing it does), then weight differential is greater.
Mike
With Lippert Frame I would be hesitant to use ANY gooseneck set up
5vrs frame rails for overhead are straight and set wide apart with pin box attached to small channels/brackets
Gooseneck places stress/weight directly upward onto the pin box which does limit distributing of the stress/weight to the outward frames which are NOT braced
Gooseneck trailer has Large Bracing, frames are heavy structure that come to a center point where stress/weight gets distributed back thru those heavy frames to trailer structure supported by the heavy bracing
Simple physics...weight/stress distribution
5vr...use a 5th wheel hitch
Gooseneck...use a ball hitch
edited 02/19/21 06:47pm by Old-Biscuit *
US NAVY------USS Decatur DDG31
work2much
On the Road
dieseltruckdriver wrote: It is due to the frame stresses. Look at how heavily built your goose neck trailers are up front. It would cost too much to build an RV that heavy.
Most of the RV's on the market have frames made by Lippert. Lippert endorses the use of the Reese Goose Box with their frames so apparently the frames don't need to be any heavier or cost anymore than they already do.
I'm with Adamis, they should at least make it a factory option so you don't have to toss the factory boat anchor when you make the swap. New Horizons makes the Gen Y available on their units.
Aside from ease of hitching there is a lot to like with a gooseneck over a std. hitch.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2400 watts solar. 600ah lithium. Magnum 4000 watt inverter.
TXiceman
Full Time RVer
You do not want a goose neck trailer. They are harder to hook up, require chains and over stress the RV frames that are designed for a 5th wheel.
Ken
Amateur Radio Operator.
Old-Biscuit
Verde Valley
work2much wrote: dieseltruckdriver wrote: It is due to the frame stresses. Look at how heavily built your goose neck trailers are up front. It would cost too much to build an RV that heavy.
Lippert 5th wheel frame failures and these were using standard 5th wheel hitch....Lippert/JUNK ---words are interchangeable!
Lippert approves Reese Goose Box cause THEY own it
![[image]](https://www.forestriverforums.com/PhotoPost/data/500/medium/b.jpg)
![[image]](https://www.forestriverforums.com/attachments/photobucket/img_166829_0_c10e7297e4055b2a6cb2615ed69fee6f.jpg)
![[image]](https://www.forestriverforums.com/forums/attachment.php?attachmentid=9598&stc=1&thumb=1&d=1395785371)
![[image]](https://www.forestriverforums.com/forums/attachment.php?attachmentid=22858&d=1357863983)
Could Post all day long but you should do a little bit of research.
BB_TX
McKinney, Texas
work2much wrote: ..........
Most of the RV's on the market have frames made by Lippert. Lippert endorses the use of the Reese Goose Box with their frames so apparently the frames don't need to be any heavier or cost anymore than they already do.........
They endorse the Goosebox because it has an air bag and shock absorber like the air ride pin boxes to reduce the road shock to the frame.
