RV.Net Open Roads Forum: Fifth-Wheels: Why is 5th wheel standard vs Gooseneck?
 > Why is 5th wheel standard vs Gooseneck?
Old-Biscuit
Verde Valley
Posted: 02/19/21 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
BB_TX wrote:
work2much wrote:
Most of the RV's on the market have frames made by Lippert. Lippert endorses the use of the Reese Goose Box with their frames so apparently the frames don't need to be any heavier or cost anymore than they already do.........
They endorse the Goosebox because it has an air bag and shock absorber like the air ride pin boxes to reduce the road shock to the frame.
US NAVY------USS Decatur DDG31
adamis
Northern California
Posted: 02/19/21 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
I think some sort of shock supression is essential for either Gooseneck or 5th wheel. The failure on the frame is happening because of the intense shock caused by nearly 3000 lbs hitting repeatedly. Put the airbag in the equation and those intense shocks are reduced substantially. I suspect the Goosebox is approved specifically because of this vibration dampening.
1999 F350 Dually with 7.3 Diesel
2000 Bigfoot 10.6 Camper
Lantley
Ellicott City, Maryland
Posted: 02/19/21 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
I agree air some form of air suppression is good however 90% of 5'ers do not have any air suppression. With that in mind your basic 5th wheel hitch provides a larger platform/contact area to absorb and spread the forces of impact to the pin box vs. a typical gooseneck hitch.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
JTrac
Oklahoma
Posted: 02/19/21 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
I researched the Goose Box for several months before I bought one. I only found one issue and that was in 2015 when a fellow hit a road hazard of some sort and had frame damage. It was so bad that even his truck shut down so not sure if there would have been damage not matter what hitch. I never found any complaints of frame damage related to the Goose Box other than this one incident. I would stand to be corrected if someone knows of more. Reese introduced the Box in 2012 so plenty of time for complaints.
We changed from a 2107 F350 dually and an Excel fifth wheel last year. We towed the Excel with a Trailer Saver BD3 air ride hitch. We downsized somewhat to the Pinnacle, a single rear wheel F350 and the Goose Box. The ride is a lot better than what we had with the previous rig. It is smoother with very little rebound after hitting a bump but it may be an apples to oranges comparison as so many dynamics contribute to the type of ride you will have. Of the several truck/fifth wheel combo's we have had in past 30 years, this is the best riding. All that is good but the best part is I remove a 5 pound ball and my truck bed is ready for use. I do use safety chains but it only takes a few seconds to hook them up to the clips on my puck system.
Hookup is a breeze with the cab mounted camera on our truck. I can see where it might be a little more difficult without it.
JimT
2020 Jayco Pinnacle 32RLTS, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR
wowens79
Georgia
Posted: 02/19/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Why is a gooseneck harder on the trailer frame than a 5er? Is it because the length of the neck down to the ball is longer than a 5er?
We are thinking of going from a TT to a 5er, and just trying to learn.
2002 Chevy Silverado 1500HD 6.0l 241k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
TXiceman
Full Time RVer
Posted: 02/19/21 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
The lever arm on the GN is longer than on a 5th wheel pinbox. On either one, it takes the same force to move the trailer forward. With the longer lever arm and the same force, you get a higher stress transferred to the frame where the pinbox attaches.
Ken
Amateur Radio Operator.
work2much
On the Road
Posted: 02/19/21 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
work2much wrote:
dieseltruckdriver wrote:
It is due to the frame stresses. Look at how heavily built your goose neck trailers are up front. It would cost too much to build an RV that heavy.
I'm with Adamis, they should at least make it a factory option so you don't have to toss the factory boat anchor when you make the swap. New Horizons makes the Gen Y available on their units.
Aside from ease of hitching there is a lot to like with a gooseneck over a std. hitch.
Lippert 5th wheel frame failures and these were using standard 5th wheel hitch....Lippert/JUNK ---words are interchangeable!
Lippert approves Reese Goose Box cause THEY own it
Could Post all day long but you should do a little bit of research.
So to make your point you post a traditional kingpin and a bent frame from an obvious traumatic impact? Nothing remotely related to a Goose Box..
The goose box adapter Reese makes is more like a kingpin that fits a ball instead of a hitch.
Turning off the gaslight now...
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
work2much
On the Road
Posted: 02/19/21 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
It isn't with a modern gooseneck adaptor like a Reese Goose Box.
work2much
On the Road
Posted: 02/19/21 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.
This from Jason Lippert:
The airbag technology used in the Goose Box reduces the stress transferred to the RV frame. The combination of the airbag, dual shocks and rubber bumpers used in the Goose Box provides multi-directional shock absorption for a smoother driving experience that RV enthusiasts will greatly appreciate.
* This post was edited 02/19/21 11:52pm by work2much *
4x4ord
Alberta
Posted: 02/20/21 12:41am Link  |  Quote  |  Print  |  Notify Moderator
The Goose Box puts the same torsion on a 5ver frame as any other design goose neck adapter.
2021 F350 SRW Platinum short box 4x4.
B&W Companion
