Hannibal
Tampa Bay Area
I tow our Jayco 28RLS with our 2020 F250 on a 2.5” Curt solid ball mount, no sway control or WD. It wallers around a little bit with with passing trucks in a crosswind but nothing scary. With the 2010 F250, I use a Reese HP trunnion style WD hitch without SC for no other reason than to satisfy the rating of the hitch receiver. Tongue weight is 980~ lbs. Squats the rear of both trucks 2-1/4”. Front rises 3/8”.
https://www.amazon.com/CURT-45456-Commercial-Trailer-Receiver/dp/B00IIOBT9Q
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'. Reese HP Trunnion 800
Sjm9911
New Jersey
I had a older equilizer on mine with the 1500. I used it for the new 2500. I did not need the weight distribution at all. Im about 5200 lbs loaded. But i still use the hitch for sway control. I set it up so it has just a smidge of pressure on the bars. If you have one allready, might as well use it. Do i need it? I have no clue , but i owned it allready and more controll if i need it is better then less.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
ssthrd
Vancouver Island
Sjm9911 wrote: I had a older equilizer on mine with the 1500. I used it for the new 2500. I did not need the weight distribution at all. Im about 5200 lbs loaded. But i still use the hitch for sway control. I set it up so it has just a smidge of pressure on the bars. If you have one allready, might as well use it. Do i need it? I have no clue , but i owned it allready and more controll if i need it is better then less.
Exactly..........
2014 Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax
DeeBee, JayBee, and Jed the Black Lab
Rather than polling the crowd, why not just take it for a drive and see how it handles. My money is on it handling just fine. But some folks' idea of fine is different than others.
By the numbers, you can hook and go easily and be nowhere near exceeding ANY rating on the truck. That should be a telltale sign.
blt2ski
Kirkland, Wa
What I noticed pulling my TT no bars, vs basics WD vs fuel cam with a 3500 CC GM LB. Approx 650-750 HW and 6000-6500 lb on axles depending on if a weekend, long week, ski weekend...
ALL setups stable, no uncontrolled fishtail sway etc.
When I did notice a difference, it was cross winds. Trailer leaned and moved side to side more without. Less with WD, less yet with dual cam. If that's not an issue to you, great. If the wind was strong enough, I would suspect the trailer would go over sideways with out, vs whole kit and caboodle with the dual cam attached.
I do admit, u preferred bars attached. Reality I was fine. I barely pulled but 60-80 lbs off the FA attached.
Marty
Check RV.Net Blogs at: blog.rv.net
mkirsch
Rochester, NY
packpe89 wrote: I have always used a WDH w/sway (cheap one they threw in when I got the TT).
Cheap as in an old fashioned friction sway bar, right?
You can use that without the WDH bars. Better than nothing.
If you have an integrated WDH/sway control like a Reese Dual Cam or another of that type, you need the entire hitch installed and adjusted somewhat properly to get any benefit of sway control.
Friction sway bars, however, can be used independently.
CharlesinGA
South of Atlanta, Georgia
packpe89 wrote: Haven't pulled my camper yet with my new to me 2016 2500 Megacab. My travel trailer is 28' and 5500#. I have always used a WDH w/sway (cheap one they threw in when I got the TT). Like most, it is a 2" bar. The Ram has a class V hitch, 2-1/2" receiver. I have the sleeve, to use the WDH, but wondering if I would be better off, just using a class V and forgo the WDH. I have all I need either way, so really just wondering which is best, thinking there could be some movement in the WDH using the sleeve.
Thanks
Joe
This sure does sound like you are citing a dry weight for the trailer. I would expect a 28 ft trailer to have a gross weight of 7K to 8K.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
miltvill
Ft. Lauderdale FL
So you don't need sway control.
Some of the trailers in this video are tail heavy.
edited 02/27/21 10:06am by miltvill *
2020 GMC Denali\Duramax 3500HD Dually Crew Cab
Sold-Trail Cruiser TC23QB
Lynnmor
Red Lion
Some are obviously tail heavy, I would bet that they all are.
blt2ski
Kirkland, Wa
A WDH or anti sway bars ultimately do not work for tail heavy rigs. As you have to ultimately move wieght from rear to front, or add to front to have a trailer that will pull straight.
Bars in such a case, is putting a band aid on a major artery cut when you need a tourniquet!
Marty
