RV.Net Open Roads Forum: Fifth-Wheels: Jayco?
 > Jayco?
timn
oklahoma
Posted: 02/19/21 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Ok we have been looking for a new 5th wheel that is small enough to pull a utility trailer behind with our sxs. Looked at jayco today and liked the 28.5 rsts. Anyone have any comments about it. Anyone have any ideas on any others. Salesman said he wouldn't recommend double Pane windows. This looking and trying to decide will wear you out. Thanks for any help.
Death Valley NP
Posted: 02/19/21 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Ordering double pane windows depends on your camping locations and expected weather. The salesman must not have any double panes in stock. He/she wants to make a sale. Get what you want.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
way2roll
Wilmington NC
Posted: 02/20/21 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Can't comment on that unit, but the salesman recommended against double pane windows?
Lynnmor
Red Lion
Posted: 02/20/21 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Double pane are not thermopane windows that are completely sealed. The space between the two panes of glass can get water or dust inside and can be expensive to repair.
Shal36
Winter Springs, FL
Posted: 02/20/21 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Go to the Jayco Owners forum and do a search. Some of these HTs are having wall separation and frame crack issues. Not sure about that specific model. Good info out on the owner forum.
If looking at brand new, both issues may be resolved. If used, they are in play.
They are also using an OEM pin box that cannot be swapped out for a standard pin box on many of the HT units. That’s a non-starter for me.
MFL
Midwest
Posted: 02/20/21 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Many of the HT models have a low CCC, due to lighter duty 4,400 lb axles. Most of these type FWs have small fresh water, and gray/black tanks to stay under a low GVWR of around 10K.
If you add another small trailer hitch wt on the very rear, just amplifies the load on frame and suspension. Will it work? Probably, but something to consider. Going to a trailer, in similar size, but with 5,200 axles, is a good upgrade.
Jerry
mabynack
Panama City
Posted: 02/20/21 08:07am Link  |  Quote  |  Print  |  Notify Moderator
I have a JAYCO Eagle and I would recommend getting the double pane windows. I bought mine after Hurricane Michael destroyed my house and we lived in it for 2 years. We couldn't keep the RV cool in the summer even with blackout shades on all the windows, extra insulation in the pantry and closets, and foam covers in the vents. We ran both A/C units and they would kick on early in the morning and run constantly until well after dark. Inside temperatures would get into the mid 80s on sunny days.
theoldwizard1
SE MI
Posted: 02/20/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
So you will be pulling TWO TRAILERS ?
You had better have a goo welder re-enforce the frame on that 5er !
timn
oklahoma
Posted: 02/20/21 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yes I will be pulling a small trailer would they put a receiver hitch if you couldn't? Yes the salesman said not to put dual pane tinted safety glass windows on it when we order said it just wasn't worth it. Salesman said this model had really good insulation. If not I really don't want one.
MFL
Midwest
Posted: 02/21/21 06:16am Link  |  Quote  |  Print  |  Notify Moderator
My Canyon Trail is 31' and came with a solid built factory receiver hitch. I tow a small trailer, about 12-15 hundred lbs when loaded with motorcycles. I have 5,200 lb axles and frame/springs that allow a huge CCC. I do feel the effect of the added trailer on bumps, bridges, etc.
While my factory hitch on FW rear is well built, very solid, across frame, with heavy square tubular steel, it is only rated for 300 lbs tongue wt.
Mine is very well insulated (advertised 4-season) with good quality, dark tinted, single pane safety glass.
Jerry
 > Jayco?
