RV.Net Open Roads Forum: Fifth-Wheels: Jayco?
 > Jayco?
JTrac
Oklahoma
Posted: 02/21/21 06:52am Link  |  Quote  |  Print  |  Notify Moderator
We have a Pinnacle with single pane windows. Our previous fifth wheel had dual pane. After 4 or 5 seasons they started to fog. They are not comparable to a sealed window you have in your home and as stated are just 2 panes of glass. I think they do help some which is common sense but we didn't want them again. We've had our Pinnacle out on some really hot days and I did have to close the shades where the sun hit the windows. We didn't have any problems keeping it cool.
Look up the Josh the RV Nerd at Haylett RV in Michigan. He has some really interesting videos, including one on the dual pane windows. He is also a Jayco dealer.
* This post was edited 02/21/21 07:11am by JTrac *
JimT
2020 Jayco Pinnacle 32RLTS, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR
Let's Go Exploring
Mandeville, La
Posted: 02/21/21 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
WE have a Jayco Eagle HT 28.5 on order. While we were thinking about the dual pane windows, once we found out that they weren't sealed, it really was not the $$ in our opinion. Talking to others, it sounds like the dual pane does more to prevent some moisture on the interior of window on cold days.
As for the additional trailer, as long as it is small / light, I dont think you will have a problem.
April & Tom (and son Brian when he is in town!)
2021 Jayco Eagle HT 28.5
2021 Ford F350 XLT 4X4 Crew Cab w/ 7.3L Engine and 4:30 Rear.
Life is meant to be enjoyed. Find ways to make it happen! ">
Hiking and Geocaching Rocks!
Njmurvin
Simi Valley
Posted: 02/25/21 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmmmm. My Arctic Fox is 10 years old and the dual pane windows are holding up very well. Not sure if they're sealed like the ones at home. But, no evidence of fogging or water leaking between panes.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
work2much
On the Road
Posted: 02/25/21 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
1600 pounds of cargo capacity? That would be a deal breaker for me. By the time you fill the fresh tank, add a couple batteries and fill the propane there isn't much left for food, clothes, tools, BBQ, chairs, beer etc etc...
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
Ranger431
Huntsville, AL
Posted: 02/26/21 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
Can't comment on that specific floorplan, but of the 5 RVs I've had in my life, 4 have been Jaycos. Started with a HTT a long time ago, had 2 TTs, went to another brand, and when the time came to get a 5er, went right back to Jayco. Obviously I'm a big fan.
2020 Jayco Eagle 355 MBQS
2011 Ford F-350
GDS-3950BH
DC
Posted: 02/27/21 07:25am Link  |  Quote  |  Print  |  Notify Moderator
timn wrote:
Salesman said this model had really good insulation.
Sure he did. What was he supposed to say? This model has really bad insulation?
Fact is it has the same or close to same insulation as just about everything else out there that rolls out of Indiana. Sidewalls are 1-3/8" beaded foam that may get R7 on a good day. Anywhere they use fiberglass Batts such as Roof and front cap will just be thrown in by some fast moving worker with plenty of gaps and sloppy workmanship.
work2much
On the Road
Posted: 02/27/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
timn wrote:
Ok we have been looking for a new 5th wheel that is small enough to pull a utility trailer behind with our sxs.
So you will be pulling TWO TRAILERS ?
You had better have a goo welder re-enforce the frame on that 5er !
Jayco rates the hitch for 3000/300 pounds and includes the electric connector and safety chain loops. A small utility trailer shouldn't be a big deal.
 > Jayco?
