BFL13
Victoria, BC
mtofell1 wrote: +/5 years old and this problems seems to be happening with more frequency. The unit starts and runs just fine but the green "power output" light is off and there is no power output. So, I turn it off and restart it and it produces power. Great.... but why is it doing this and I fear sometime it's just going to stop altogether. Several times I've had to stop/start 3-4X to get it to produce power. I'll likely just take it into a Honda dealer but in the meantime am curious what it going on.
Assuming there is nothing plugged into the gen when you start it, the inverter should come on. If you then overload the inverter, it will trip the breaker but the motor keeps running. Reset requires a restart of the motor.
Seems like your inverter is acting up at times, or the breaker is faulty so it sometimes thinks it is overloaded? The inverter gets its power from the "revolving field" of the engine at spec rpm.
If the rpm is not high enough or slows down while running, not enough "field". Is it running at full speed?
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
mtofell1
Oregon
As mentioned in OP, green light is not always on - if it is I have power and all is well, if it's off I have no power
Definitely not overloading it. I'm very aware of the capability and don't plug in too much. While testing/troubleshooting I was using a lamp or just an outlet tester
The reset breaker seems to have no purpose.... it's just lazy and loose. I'd be suspect that it needed to be reset but I don't touch it and go from no power to power with cycling the generator off/on. If something with the breaker was the issue I can't imagine it would produce power, then not, then produce power, etc.
Thanks for the replies about the Honda generator.
pianotuna
Regina, SK, Canada
I'm not certain--but I think the reset breaker is for the 12 volt side of the generator--not for the inverter part.
I am going to guess there is a loose wire.
Regards, Don
opnspaces
San Diego Ca
The reset breaker on mine is also just sloppy and loose and never seems to do anything.
What about starting the generator with no load plugged in, does the green light come on and then go off if you apply load? Or does the light not come on at all?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
enblethen
Moses Lake, WA
Reset is on 120 volt circuit. It should be obvious that is popped out. Button doesn't attach to anything in the circuit breaker until the breaker trips.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
magbarn
Sounds like the inverter board may be bad. Unfortunately that usually means retiring that genny. Did you run it under high load or overloaded for prolonged periods of time?
