RV.Net Open Roads Forum: Travel Trailers: Problems with 7 Pin Connector
 > Problems with 7 Pin Connector
Taffy.C
MN
Posted: 02/20/21 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Hi There,
Having issues with the 7 Pin trailer connection between my trailer and TV. I can't seem to get all contacts connecting at once - I I jiggle the connection slightly I can get brakes connected but I lose one or more light connections and vice-versa.
I've tried using a very find grade wet/dry sandpaper to clean the contacts but that only brought minor improvements. I'm thinking that maybe the connections are too sloppy and maybe I need to replace the trailer connector plug. The trailer is 18 years old.
I'd welcome any suggestions on this - not sure how difficult it is to replace the connector too. Also, because I have a hensley hitch that added a few inches to the trailer length, I don't have any room to lose length on the electrical cable (which I figure might happen when I replace the connector plug). If anything I need to make it longer.
Any help much appreciated,
Daniel.
2003 Explorer Limited 4X4 V8 Advancetrac 3.73 Axle
Jayco Kiwi Too 22U
Hensley Arrow
Prodigy
jdc1
Rescue, Ca
Posted: 02/20/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes I have to use a screwdriver to bend the prongs for better contact. I use lithium grease on my wife's plug-in Prius cord, and that really helps.
deltabravo
Spokane, WA
Posted: 02/20/21 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Some plugs on trailer cords have an undersized diameter on the plug, so they fit really loose and sloppy in a truck OEM plug.
I had the same problem. I replaced the entire cord / molded plug with a different brand, problem solved.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
Death Valley NP
Posted: 02/20/21 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my 7 pin connector and no problems since.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MitchF150
Puyallup, WA
Posted: 02/20/21 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
That happened to me a long time ago.. I took a small flat blade screw diver and pulled the 'female' side prongs out in each socket and then sprayed some wd40 into the plug and that fixed it.. It was only a plug connection issue in my case, but if it's a wiring issue, then more work will need to be done to diag it..
Good luck, Mitch
Taffy.C
MN
Posted: 02/20/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. Pretty sure the wiring is fine so I guess I'll start with the screwdriver and WD40. Hopefully its that simple[emoticon]
rr2254545
Central Minnesota
Posted: 02/20/21 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Had the same problem replaced the female plug on the RV, no problems since then - it was not the cord -
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee, Air Force One, Blue Ox Avail tow bar
374 Campgrounds,85K miles driven in our Winnebago motor homes and 1858 nights camping since we retired in July 2009
Diamond c
West ky
Posted: 02/20/21 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
If the prongs have a split in the middle of them take a small flat blade screw driver, put it in the split and spread them so that they fit tighter. This works for me on the pigtail of my tractor trailer.
Gdetrailer
PA
Posted: 02/20/21 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
You can try to clean them, scrub them, adjust the prongs but after a while weather and age takes a toll on the plugs..
For $6 and a little bit of your time you can just replace the plug and be done with the issue for quit some time..
FOUND HERE
For less than $30 you can buy not only the plug but the entire harness with the plug molded in to the harness with 8ft of wire..
FOUND HERE
That one looked interesting since it has double prong contacts in the plug rather than standard single prong contacts..
JRscooby
Indepmo
Posted: 02/21/21 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Commercial with round holes/pins is much easier.
I have used 2 pair of needle-nose pliers to bend a slight V in the length of the blade, then flatten the ends so the plug will start back on. Less work to replace the plug, and likely only last for 1 trip.
