RV.Net Open Roads Forum: Fifth-Wheels: No hot water in kitchen
 > No hot water in kitchen
rdmotex3
Posted: 02/20/21 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hoping for some help. Just finished a week of “generational cold” here in south Texas. Five days of bitter cold with the lowest temp of 9. I did not winterize our relfection prior to the storm. I drained it well after our last trip but I have no doubt there was residual water lines. Also, I did not drain hot water heater. Today was first day with sun and not frozen so I hooked up the camper and everything seemed to work and no apparent leaks. However, the water in the kitchen only turns tepid and never hot. I found a blog about the outdoor shower valves could be causing an issue if left on. Went out to check and sure enough they were on! Problem solved!! Nope still only tepid water I the kitchen. After an exhaustive search online with no luck I posted this question on a Facebook group. The best thought from that post was the hot water line in the kitchen was still frozen. Possible? I guess but it seems odd that would be the only line still frozen. Anyone else have any thoughts or heard this before?
Bishop area, California
Posted: 02/20/21 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Either the hot water line into the kitchen faucet is clogged or it isn’t. It is something else. .
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
ssthrd
Vancouver Island
Posted: 02/20/21 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
I just went thru this.........
My bet is that your kitchen sink water lines are t'eed off the low point drains for both hot and cold. If you look under the sink, remove the mouse blockers if you have them and shine a flashlight down the hole. Chances are you will see ice. The low point drains on my RV are exposed under the RV, and are probably the first thing to freeze in cold weather. I put a small heater in the cupboard and just waited. Sure enough after an hour or so, the hot water worked again.
I have not done it yet, but I will insulate and put some heat tape on them when I can.
It's still a mystery to me that the cold water line which is next to the hot water line did not freeze.
Hope you and yours are dealing well with the deep freeze.
2014 Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax
DeeBee, JayBee, and Jed the Black Lab
rdmotex3
Posted: 02/21/21 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Pulled the mouse boards and can’t see anything. We are 48 hours past last freeze. We were in the 60’s yesterday and mid 70’s today. I’m beginning to wonder if ice is the problem. Any other suggestions out there?
opnspaces
San Diego Ca
Posted: 02/21/21 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Two days of 60-70 degree heat I don't think you have an ice problem. Do you have hot water anywhere in the coach and only not at the kitchen faucet?
Sit back for a minute and just take in the trailer. Think about the location of the water heater to the faucets. Most likely the trailer only has one water line that runs from the fresh tank, through the heater and then to all the fixtures.
Run run hot at the working faucets and then start tracing the water lines touching the outside of the lines until the temp goes from hot to warm. Hopefully you can open cabinets or pull out drawers to reach the lines. You checked the outside shower knobs, what about the inside shower?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
MFL
Midwest
Posted: 02/21/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
I agree with this, but wonder if only kitchen faucet, lukewarm, could it be mixing hot/cold, just a little, if a single handle faucet? Most RV faucets, not best quality!
Jerry
rdmotex3
Posted: 02/21/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Insert head shake here. So I took the advice from opnspaces and sat back in order to take it all in. Traced the lines rechecked everything and as you can imagine nothing. Frustrated and beginning to accept defeat a thought occurred to me. I thought zero chance but I did it anyway. I took off the head on the sink and ran the hot water. It spit and sputter and then piping hot water. Inspected everything and still no idea as to the what or the why. Put it all back together and boom it’s working. Could I have missed something? Maybe? possibly? I don’t know for sure but it’s working. This one has me shaking my head.
MFL
Midwest
Posted: 02/21/21 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Glad you got it working! Lol, no man should have to accept defeat, from a non-working device!![emoticon]
Jerry
larry barnhart
wenatchee. wa usa
Posted: 02/21/21 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
the 2 times we had no hot water in the rear kitchen was the check valve on the water tank was pluged. chevman PS not a winter condition.
chevman
2021 Jayco Hawk 28RL
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
jdc1
Rescue, Ca
Posted: 02/21/21 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Heck. The water may not have been hot when you were running around trying to figure it out.
