RV.Net Open Roads Forum: Palomino SS 1251 Pop-Up on 1/2 Ton Pickup
 > Palomino SS 1251 Pop-Up on 1/2 Ton Pickup
Route66Cruisers
Santa Fe, N.M.
Posted: 02/20/21 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
Palomino markets it’s SS 1251 Pop-up Truck Camper as made for 1/2 ton pickups. We have 2010 F-150 SuperCrew F-150 5.4 4x4 6.5 bed and are interested in buying the SS 1251.
At age 71 we want to avoid buying a 3/4 pickup. We are hoping for some feedback only from members who have experience with this specific camper on their 1/2 ton truck.
Mike & Kewpie
2010 Ford F-150, SuperCrew,5.4 Triton V-8, Tow Package, long bed
2008 FunFinder 189FBS
camp-n-family
London, Ontario
Posted: 02/21/21 05:21am Link  |  Quote  |  Print  |  Notify Moderator
I don’t have experience with that camper but I’m doubtful that it will work with your truck. The manufacturers get away with sales talk like “half ton towable” because they were able to spec 1 truck with the number to do it. In this case it’s likely a bare bones single cab heavy payload truck. This is a rare beast which I suspect you don’t have.
The brochure shows a dry weight of 1910lbs and a gvwr of 2627lbs. Not many 1/2 ton trucks have the payload, or more importantly the axle capacity for that much weight. You still have to add passenger weight onto that. What’s the payload sticker on your door say? Better yet, load your truck with fuel and passengers and go to a scale. Weigh each axle and see what capacity you have left for a camper. You’re going to need close to 3000lbs of capacity on the rear axle. I see a rawr of only 3850lbs listed for non heavy duty option f150. Approximately 2400lbs of that is used up with an empty truck leaving only 1450lbs for camper weight.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
JimK-NY
NY
Posted: 02/21/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I agree. Skip the Palomino or any other popup. If you want to stick to a F150 you will save money and have way better and more comfortable choices with a small trailer. If you want a TC, skip the F150 and F250 and head directly to a full 1 ton pickup.
I am not sure what being 71 has to do with it. If you have the money start with a 1t truck. If not and cost is a major concern look at smaller used trailers.
billtex
RI
Posted: 02/21/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Reading comprehension not a strong suit here...
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
KD4UPL
Swoope, VA
Posted: 02/21/21 07:45am Link  |  Quote  |  Print  |  Notify Moderator
I had a Palamino 8' pop up TC on a 1996 Dodge 1500 ext. cab 4wd. With just the camper loaded up and the tailgate and spare tire removed I was about 600 pounds over the truck's GVWR. I tried to never put much gear inside at all knowing that I was already so heavy. I was a young single man at the time so I didn't need much gear. Also, it was generally just me in the cab. So, by adding E load range tires, Rancho shocks, and air bags I was able to make it work.
This camper was pretty bare bones; it had no air conditioner, no water heater, no bathroom, only 1 propane tank, and no sewer tanks.
That camper shows an UVW of 1,795. Adding 20 pounds of propane, 15 gallons of water, and a battery will put you at almost 2,000 pounds. I would say loaded with food, clothes, dishes, etc you will be pushing 2,500 pounds.
Weigh your truck's rear axle with you and the wife in the cab, a full fuel tank, and no tailgate. Subtract that weight from the truck's RAWR on the door sticker and see if you have 2,500 pounds left.
Geewizard
WA
Posted: 02/21/21 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Are you interested in a similar setup and my experience with it?
Very similar to KD4UPL's post.....
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
200W solar, MPPT controller, LED lights
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
Route66Cruisers
Santa Fe, N.M.
Posted: 02/21/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the helpful information.
* This post was last edited 02/21/21 10:35am by Route66Cruisers *   View edit history
Lake Crowley area, California
Posted: 02/21/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
I’m 71 and love my new pickup. Having a TV that is completely adequate for carrying a TC will make your camping much more enjoyable...and you’ll be level too.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mkirsch
Rochester, NY
Posted: 02/22/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Virtually NOBODY has this specific experience that the OP is looking for.
