RV.Net Open Roads Forum: Tech Issues: Where would my LP regulator leak?
 > Where would my LP regulator leak?
wopachop
Who run bartertown
Posted: 02/21/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Been chasing an intermittent propane leak. I think it must be my regulator, but i have not found a place making soapy bubbles. I will pressurize the system and then close the propane valve and watch the dial. Sometimes it will lose pressure in 2 minutes. Other times it will hold pressure all night long. Ive tried setting the regulator to different positions and cant seem to make it leak enough that i can confirm with soapy bubbles before buying a new regulator.
Do you think maybe its leaking at the ACME nut instead? I recently bought 2 new hoses which i hoped would solve my problem. (both hoses would leak slightly). I noticed the new ACME nuts sure felt hard to turn on both hoses. Spraying soapy water everywhere i cant find the leak.
enblethen
Moses Lake, WA
Posted: 02/21/21 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Regulator vent
pipe connections, verify that there is yellow Teflon tape
O-ring inside pigtails
connection at appliances
connections where appliances tap off iron pipe under rig
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Beatty, NV
Posted: 02/21/21 11:57am Link  |  Quote  |  Print  |  Notify Moderator
How old is the regulator? Eight to ten years is about the max IMO.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
philh
Belleville MI
Posted: 02/21/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
I had to replace both the valve and one pigtail (did both), to stop the leak. This is on a 2 year old TT. when I drained a tank after just one day on a heater (barely used), I went looking for the leaks.
Old-Biscuit
Verde Valley
Posted: 02/21/21 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
WHAT do you mean by that highlighted statement??
LP leaks
Probably that 'gauge' (really useless cause they work on pressure and the cylinder will have pressure until almost empty---10#)
1st Stage Vent....small pencil size hole in body
2nd Stage Vent....1/2" hole in body
Body Crimp areas
Pigtail...bushing/hose connection on backside of ACME Nut
*How hard of a bend is in that pigtail (reg to cylinder should be a easy swooping bend NOT tight curve)
Hard to tell from PIC
That big knob (haven't seen one like that)....should POINT towards the cylinder in service NOT Up/Down like in PIC
What brand Reg is that?
LP Portable Leak Detector (sniffer) are inexpensive and WILL find very small leaks (roughly $33 or less) and No Messy Soap Residue
*Small leaks may NOT produce visible bubbles
chiefneon
Livingston, TX
Posted: 02/21/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Howdy!
I had a propane leak I could not find using he typical method of soaping and checking for bubbles. I ended up purchasing a Leak Sniffer Detector on Amazon and found the leak right away.
Propane leak sniffer detoctor
“Happy Trails”
Chiefneon
BB_TX
McKinney, Texas
Posted: 02/21/21 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Look for a very small vent hole in the regulator. If the membrane in the regulator is leaking, the propane will escape thru that hole. My regulator was turned in a position I could not see the vent hole and could not get soapy water on it. Therefore no bubbles. Took the regulator off and there was oily residue around that vent. Replaced the regulator and all good.
Curly2001
Tucson, Arizona
Posted: 02/22/21 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue and replaced one hose and the regulator. Then decided to replace the other hose. Problem solved. The hoses will start to leak around the crimps as well as the regulator around the diaphragm. I could smell the leak but could not find it using leak detector. The hoses were getting a little "crispy" anyway so it was prudent to replace them with the regulator.
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
smarty
new mexico
Posted: 02/22/21 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Happened to me last week
Ours turned out to be a missing washer in the hose that attaches to the propane tank
