RV.Net Open Roads Forum: Tech Issues: FloJet Macerator Capabilities -Unique (embarassing) Question
 > FloJet Macerator Capabilities -Unique (embarassing) Question
TURNKEY
Saskatoon,Sask,Canada
Posted: 02/21/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
I am interested in getting a FloJet Portable Macerator pump. Looking at on line images of the pump it appears the part of the pump assembly that connects from the rv bayonet dump fitting to the actual blade housing of the macerator is a funnel shape that goes from about 3" to about 1.5".
My question refers to the actual 'size' and 'firmness' capabilities of the pump. Can it handle something as large as tennis ball and very firm? It looks like the taper of the funnel could prevent a large 'object' from actually reaching the blades. Or is it the case that if it can fit through the valve gate (aside from clogging type material like hair and baby wipes) it is pump-able?
TURNKEY">
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 02/21/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Baby wipe's should not be put through a macerator as they will not tear apart enough and will jam the pump, most anything else will cause no trouble at the pump. Just my thought's.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 28' 5th wheel Travel Aire. Lots of fun.
TURNKEY
Posted: 02/21/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
That is what I already said about wipes. What about large 'objects' getting stuck in the FloJet funnel and not making it to the macerator?
mbopp
Henrietta, NY, USA
Posted: 02/21/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I just looked - the throat on mine is 1-3/8". No, it will not pass a tennis ball. Or women's sanitary products. Or anything solid, the steel impeller needs to grind it up to pass through the garden hose fitting. Once a year I disassemble it to remove the hair wrapped around the impeller.
I always had a bit of water come out when disconnecting it. Now I use a 45-degree clear elbow so all the water goes into the pump. For hose I use corrugated pond or water feature hose. It's light, coils easily for storage, and is a full 3/4" diameter.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
RobWNY
Jamestown, NY
Posted: 02/21/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
I have a Flojet Macerator and it will not accommodate anything the size of a tennis ball. You are correct that it is about 3" in diameter and tapers down to an opening 1.25"-1.5" (hard to measure exactly) before getting to the blades. If what you need to go through it is very firm, it needs to be narrower than the opening.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
Old-Biscuit
Verde Valley
Posted: 02/21/21 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
WHY would you have 'tennis balls' in your Waste Tank??
POOP (even a Large one) will NOT clog up the inlet to macerator
Liquid to POOP ratio....needs to be high ---water is your friend
When POOPing fill toilet bowl BEFORE you flush then let a couple seconds of water flow when you flush
POOP when wet (EVEN a LARGE one0 will soften, turn gooey and flow right into that macerator and be ground up into small pieces of poop that will then be pumped out the discharge hose (use 3/4" Garden Hose)
I have had a Flojet Portable since 2008....pumps 75' with a 2' rise W/O issue
Then when done pumping connect another garden hose and flush clean water thru it to clear pump and discharge hose
I take mine apart at end of season and check the cutter blade (steel) and the Impeller (rubber)-----clean up any hair etc.
Done
But keep the tennis balls out of waste tanks
US NAVY------USS Decatur DDG31
Wherever I happen to park
Posted: 02/21/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Nice post but one nit. The impellers are rubber not steel. The Steel blades are the macerator, all they do is break up semi solids and stir the soup as it were. Below them is a metal plate and below that are the rubber impellers. Just so you know.
Other than that one nit. Good post.
Home is where I park it.
TURNKEY
Posted: 02/21/21 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Old Biscuit I asked about tennis ball sized **** not tennis balls. Not everybody spits out BB's like you. Thanks for the detailed explanation about what YOU do but it was no help at at.
* This post was edited 02/21/21 05:57pm by TURNKEY *
Old-Biscuit
Verde Valley
Posted: 02/21/21 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Comprehension is not your suit I take it
So POOP away and have a Stir Stick Close by
PastorCharlie
NC
Posted: 02/21/21 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have used my macerator up to 150 feet runs and pump 100 plus gallons in 10-15 minutes. It has a hose connection for flushing it after pumping tanks that cleans out pump and hoses. After pumping I disconnect the pump and spray the inside propellers with a liberal coat of penetrating oil. It prevents it from sticking after sitting dry.
I ran a dedicated fused circuit from batteries to dump bay and plug the pump into it.
I have different lengths of 3/4 commercial hoses that are adaptable for different distances with a combination of all to 150 feet.
I have never had any problem dumping the tanks. I see no problem with the pump size if the tanks are used proper.
