RV.Net Open Roads Forum: A terrible dinette table. Opinions on modification?
 > A terrible dinette table. Opinions on modification?
Boomerweps
Hills of PA
Posted: 02/24/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Rounding the corners, even an inch, or two, in radius would make a huge difference in comfort. Four small openings when the table top is in the bed position won’t matter. I’d just pencil in the radius using an appropriate round lid off a plastic container and use a belt sander to round it out. A little smoothing with a finishing sander, some dark stain on the wood and done. Keep it simple, and near no cost.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
profdant139
Posted: 02/24/21 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Boomer, you are right about the corners. But some dinette tables are not wood -- they are made of MDF, with a plastic overlay. As soon as you cut into the plastic, that ugly MDF shows up -- it is basically compressed cardboard. Not sure if that is true of the OP's table.
The other trick is getting the plastic laminate to cut cleanly. I've tried all sorts of blades on my scroll saw, at various speeds, and have never been satisfied with my work -- there are always chips in the plastic.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
PrivatePilot
Greater Toronto Area
Posted: 02/24/21 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
So I spoke to some people with the newer generation of my exact Trailer that does have a round table as opposed to rectangular, however at the same time does not have spacers or anything for the gaps the table leaves.
Apparently the secret is that the 2 cushions that go down over the table gap have thin plywood backers between the outside material and the foam. So they become part of the structure and bridge the gap the round table leaves.
Aha!
30' Keystone Cougar 5'er, Triple Bunkhouse, SuperSlide.
Chevy 3500 1 Ton long box crew cab dually
6.5 Turbo Diesel, 4.11 Rears, LSD, Fresh rebuild spring 2012.
Dieselplace.com Staff Member
Our 2008 western adventure - to the coast and back!
Mark
Sjm9911
New Jersey
Posted: 02/24/21 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Router with laminite blade. At least thats how we did it in shop class 35 years ago.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
profdant139
Posted: 02/24/21 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
Good idea! I've got to get a router and learn how to use it safely.
Sjm9911
New Jersey
Posted: 02/24/21 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thats why the solid wood table is a good idea, after 35 years i would need to learn how to cut laminate again also! Lol.
