RV.Net Open Roads Forum: Tech Issues: Furnace/water heater
 > Furnace/water heater
dmark67
Pueblo, CO
Posted: 02/22/21 06:41am Link  |  Quote  |  Print  |  Notify Moderator
Propane flowing - stove works.
Furnace and water heater will not start?
schlep1967
Harrisburg, PA
Posted: 02/22/21 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Both run off 12 volt. Is the battery charged and the battery cut-off switch turned on?
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
pianotuna
Regina, SK, Canada
Posted: 02/22/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Hi dmark67,
Welcome to the forums.
May I ask how cold it is outside?
Regards, Don
Old-Biscuit
Verde Valley
Posted: 02/22/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
This^^^^
Propane is common but stove OK then DC Voltage is the other common component
***first time trying furnace/water in awhile......then could be propane flow
Might have to try each appliances several times to establish full flow/pressure at each one
dmark67
Pueblo, CO
Posted: 02/22/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
It's cold, from 0-10 degrees. I waited several hours and now it works...
On shore power and not DC, no problem with anything else (TV, microwave, etc.).
Got to hot in the middle of the night?
Boon Docker
Posted: 02/22/21 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
This^^^^
That was more than likely the problem.
dmark67
Pueblo, CO
Posted: 02/23/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Hint:
Propane water heater and stove are working. I took the outside cover off the furnance and there is a circuit board with a red light blinking. Did the reset, no luck. All of my manuals say contact the dealer lol.
Ideas?
pianotuna
Regina, SK, Canada
Posted: 02/23/21 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
dmark67 remove all power to the furnace. Wait ten minutes. Pray to the propane gods and restore power.
