RV.Net Open Roads Forum: OBD-i and OBD-ii did a '96-'97 F53 ever have diagnostic plug
 > OBD-i and OBD-ii did a '96-'97 F53 ever have diagnostic plug
genentina
Ladera Ranch, California
Posted: 02/22/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
I have a situation trying to have a smog check done on my F53 chassis, the chassis was Ford built June '96 but the MH is registered as a '97,
and either way the local California smog test station I go to now after smogging it for me over past 20 years now wants to plug in to an OBD-ii connector and there isn't one.
Smog checks are required here every 2 years in order to re-register. The CA Bureau of Automotive repairs lists our 17,000 chassis as having the OBD plug but it isn't there, never has been.
Anyone know a way around this problem?
Get off the phone and drive!
enblethen
Moses Lake, WA
Posted: 02/22/21 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Not sure about your year.
Some Ford F53 has the OBD connector mounted high on the steering column under the dash. It has a funny cover protecting the receptacle.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Yankee Clipper
Cairo, GA
Posted: 02/22/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
My 1997 Coachmen Catalina had an OBD-1 under the doghouse on the driver's side. PITA to get at it.
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, Duke the overgrown Boxer mascot/lousy watch dog
Rosey the minidachshund resident Princess-in-Chief
genentina
Posted: 02/22/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
the chassis is a Ford 1996 F53 built June 1996
The registration says Georgie Boy 1997
so under the engine hatch or high on the steering column?
genentina
Posted: 02/22/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
high on the steering column and under the dash sounds impossible to get access.
I went through both of the Ford manuals on the chassis and there is no mention
of an OBD plug or diagnostics plug anywhere.
dodge guy
Bartlett IL
Posted: 02/22/21 11:48am Link  |  Quote  |  Print  |  Notify Moderator
Not sure if it has an OBD II connector on an F53. I had a 95 Explorer that had the OBDII connector but the system was still running EEC IV software. Its very possible the F53 may still have an EEC IV connector under the hood.
If it has the OBDII connector it should be on the right side of the steering column either mounted to the plastic dash or on the column itself
Either way, that's Cali for ya!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
MountainAir05
New Mexico
I think like stated under the dog house toward the Left wheel on the firewall or just in front of the left wheel inboard. Use to be some pictures on here somewhere.
https://www.google.com/search?q=1996+obd1+connector+F53+chassis&client=firefox-b-1-d&tbm=isch&source=iu&ictx=1&fir=cWY6CzKvXHYktM%252ClAM1ja74UHVeAM%252C_&vet=1&usg=AI4_-kS3N0KFLVvp9ASIOsElG-GqKiNsLw&sa=X&ved=2ahUKEwii8f-QlP7uAhWdAZ0JHXbmD0UQ9QF6BAgdEAE#imgrc=cWY6CzKvXHYktM
just info. this is not the same shape as the obd11 connector. Only has 3 to 5 pins . this has pictures where it is located
* This post was last edited 02/22/21 12:42pm by MountainAir05 *   View edit history
genentina
Posted: 02/22/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
ok, I'll keep searching. Would it be mentioned in the owners manuals if it has it???
enblethen
Moses Lake, WA
Posted: 02/22/21 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Found this on another website
the F53 chassis in 1997 was still running EEC IV engine control system due to the GVW of the vehicle exempting it from OBDII requirements. You'll find the EEC IV (DLC) connector on the passenger side near the starter relay. Location varies since coach builder may move it, but should be in that area.
Krusty
Calgary, Alberta,Canada
Posted: 02/22/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
F53 wasn't OBDII until 1999 model year, which was first year of the V10. Your 460 is still EECIV and has a diagnostic connector under the hood
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
