rdhetrick
Hi all,
Trying to help my dad identify some wiring in his coach for a project. Manufacturer hasn't been any help so I thought I'd try here.
He has two wires that we are trying to identify the wire size. Seems the obvious method would be to use a set of calipers, but he doesn't have any.
Anyway, there are two stranded copper wires, each with different markings. Anyone recognize the markings or format?
Wire 1: "150 FA Ground"
Wire 2: "603c GLY LPS"
I've not been able to find anything.
Thanks in advance!
Rob
2006 Mandalay 40E Full Time
2015 Jeep Grand Cherokee
2oldman
south
For wire 1, google says "For 150 amps in THWN wire size is 1/0"
I cannot find wire 2. Perhaps compare it to wire 1, assuming it actually is 1/0. You can consult a wire table for that.
I would think all you'd need is a simple ruler to measure the diameter.
edited 02/22/21 01:03pm by 2oldman *
opnspaces
San Diego Ca
Are the markings printed on the wire as if from the wire manufacturer? Or is he talking about printed labels that were possibly installed by the coach manufacturer? I only ask because a 1/0 wire is a big wire which I find hard to believe is in a factory built RV.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
enblethen
Moses Lake, WA
OP: Please post make and model of your dad's coach
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Wherever I happen to park
The wire markings idetify the wire's FUNCTION not the size but the purpose.
Beyond that I can not help.. For BIG I"m tlaking battery size big. a ruler might help
For smaller an adjustable wrench (The one that made crescent famous)
Then measure the gap in the jaws or take it (Tape over the adjuster) to the store with you.
NOTE if you are trying to add to or replace a 18 ga wire and all you have is 16 or 14. NO PROBLEM. the other way around PROBLEM You can always "Go big"
Home is where I park it.
MEXICOWANDERER
las peñas, michoacan, mexico
Image next to a fingernail?
Death Valley NP
As said..always go bigger on any manufacturer’s wire size you are replacing.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
rdhetrick
OP here, to make a short story long...
Dad's coach is a 07 or 08 Fleetwood Bounder Diesel.
He recently had the 12v JC Refrigeration compressor unit installed and has had several problems with it. I've been helping him troubleshoot the problems.
The latest problem could possibly be a result of excessive voltage drop in the 12v supply to the JC unit. The JC unit is supplied with a connector that plugs directly into the 12v supply wires to the original Norcold unit after the Norcold is unplugged. They also state that the 12v supply wires should be minimum 10 gage. I have doubts that the original factory wiring to the Norcold was 10 gage, thus the question about the markings.
enblethen
Moses Lake, WA
I checked my wiring diagrams for my rig. They use a different coding.
Factory refer is more likely around 16 gauge.
Bobbo
Wherever I park
wa8yxm wrote: For smaller an adjustable wrench (The one that made crescent famous)
I always thought the rolls made crescent famous.
Bobbo and Lin
