TurnThePage wrote: My 2004 Fleetwood Pioneer has a 50 gallon fresh tank that is supported by two square bars (C channel might be a better description) fastened to the frame via nut and bolt. I drag that trailer through serious back country with lots of major bouncing going on with zero issues.
It's mounted directly to the trailer frame? Meaning the bars go from one side of the trailer to the other? Is there any significant bending from the weight?
schlep1967 wrote: OP if you can provide pictures of the tank and existing supports it would be easier for us to describe what you need.
I wish I had thought of that, but I already closed up the bottom cover again. It's super hard to get it screwed back in with the way they chose to screw it in.
Yep. Mounted directly to the frame. No bending at all. The bars are pretty stout though. Maybe I can find my way under there to take a pic tonight.
I'd appreciate it. I was thinking I'd have to do some cross bracing, but if I can just do straight pieces across the trailer without significant bending, that's pretty easy to put in and take out.
What size tubing did you use? I'm assuming you used steel?
