RV.Net Open Roads Forum: General RVing Issues: not sure where to post this.....
 > not sure where to post this.....
huskyfan68
usa
Posted: 02/22/21 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it's RV related (sort of...)
I have a 2009 F150 towing a 22' Wildwood. I would like to purchase a golf cart for campground use.
I believe a standard cart is a little less that 4' wide and should fit with tailgate down....
Here are my 2 questions:
1. Can you still tow a TT with the tailgate down?
2. Can you drive an electric cart up into a pickup with ramps?- Meaning does it have enough power to get up into the bed..
jdc1
Rescue, Ca
Posted: 02/22/21 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Tailgate will hit the trailer jack. If you have a shortbed, you should have asked the truck dealer for the 2 of bed they cut off. Yes....you can drive a golfcart up into the bed of a standard size (8') truck.
Beatty, NV
Posted: 02/22/21 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Possibly. Do some measuring. Ask the golf cart retailer to let you run one into the bed. Not all tailgates hit the jack. If the trailer hitch was longer?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
huskyfan68
usa
Posted: 02/22/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
thanks- so I guess a good follow up question would be- would it work with the tailgate removed?
fj12ryder
Platte City, MO
Posted: 02/22/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Some of those carts are not light though. Depending on how many batteries they are carrying.
Howard and Peggy
"Don't Panic"
Second Chance
Wherever...
Posted: 02/22/21 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
I agree - with a 2009 F150, you'll likely be over payload on the truck. Golf cars are heavy.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Lakeland Bob
Posted: 02/22/21 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
There is a cart made to do just what you are asking for. It's called a Cricket" https://cricketminigolfcarts.com/cricket-golf-cart-models/.
We had one and carried it in our 2500. It compacts for transport at 58" by 32" and weighs 330lbs + any accessories. They are very well made, use some standard parts. However, they can be a little tippy due to their narrow wheel base. They will carry 4 people and get around pretty quick.
We found ours on Craigslist for $2400 and sold it latter for $2600.
Bobbo
Wherever I park
Posted: 02/23/21 06:18am Link  |  Quote  |  Print  |  Notify Moderator
I agree with fj12ryder and Second Chance. As much argument as there is on this forum about whether an F-150 even has enough payload to tow a decent sized TT, putting a golf cart in the truck bed is guaranteed to throw you FAR over the payload limits when the TT is also hooked up. Note that Lakeland Bob at least had an F-250 (equivalent) when he got his.
Bobbo and Lin
valhalla360
No paticular place.
Posted: 02/23/21 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Hook up, lower the tailgate and start backing up to see how sharp you can turn. It might be Ok. It might NOT. It may be possible to get a hitch extension since it's a small relatively light travel trailer which would help push the pivot point back.
Yes, you can drive it up ramps into the back of a pickup. With a long bed, it should be possible to close the tailgate.
The bigger issue is payload. Gas golf carts are upwards of 600lbs and electric carts can be upwards of 1200lbs (batteries are heavy). Good chance by the time you load up the truck with people and gear, add the cart and add the hitch weight, you are over a 1/2 ton trucks payload.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
dodge guy
Bartlett IL
Posted: 02/23/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
In a short bed the tailgate will hit the Jack. If you don’t have a tall Jack the corners of the tailgate will be driven into the front of the trailer.
However....after you load the golf cart into the F150, what are you going to use to tow the trailer?
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
