RV.Net Open Roads Forum: Tech Issues: Stand Alone Charger
 > Stand Alone Charger
Grodyman
Enemy Territory
Posted: 02/24/21 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
What is the best stand alone battery charger? I have had a couple of Shcumachers and I am really not impressed. Also, there seem to be several dozen Schumacher models, how the heck do you know which one to get, they all look pretty much the same?
Also, I am considering just buying a Progressive Dynamics PD9260 and using that as a stand alone charger.
Gman
2017 F150 CC/5.5' 4x4 3.5 Ecoboost/3.55
2018 Passport Ultra-Lite 153ML
theoldwizard1
SE MI
Posted: 02/24/21 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Do you really need a 60A charger ? You would save almost $50 by downsizing to the 45A model.
BFL13
Victoria, BC
Posted: 02/24/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
The best is with adjustable voltage to work with any type of battery's specs. Price is good too. (I use converters as portable chargers with cut-off jumper cable ends in the terminals to clamp onto the battery.)
https://www.boatandrvaccessories.com/pro........er-converter-battery-charger-w-led-light
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Gjac
Milford, CT
Posted: 02/24/21 10:25am Link  |  Quote  |  Print  |  Notify Moderator
If you are going to use it to charge 2 6v GC batteries in you RV I would get the Stanley 40 amp charger about $100 or if you can find an older B&D 40 amp charger. I bought my B&D for $50 when Stanley bought them out. If not the convertors that BFL13 showed are good options especially the 45 amp for $114. If you want it just for your cars any 10 amp charger will work, Stanley makes 10,15 and 25 amp one.
rlw999
Washington State
Posted: 02/24/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
What are you using it for? Are you charging your RV's starter battery because you left the lights on all night, want a maintainer to keep your batteries charged in storage, or trying to charge your house battery bank as quickly as possible while you run the generator?
My only charger is a 2A Battery Minder, which works fine, if slow. When I left my car headlights on all night and drained the battery so low that the dome lights were barely visible, I hooked up the Battery Minder for a couple days to charge the battery.
BarabooBob
Baraboo, WI
Posted: 02/24/21 11:15am Link  |  Quote  |  Print  |  Notify Moderator
When I had my Class C, I used the PD 4245 to keep the starter battery when the RV was not in use. Never had a problem doing that.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
valhalla360
No paticular place.
Posted: 02/24/21 11:27am Link  |  Quote  |  Print  |  Notify Moderator
People are dancing around the issue: What are you trying to charge?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
fj12ryder
Platte City, MO
As was asked, what are you charging and where?
I pull my toyhauler battery in the fall when it goes into storage and put it on a BatteryTender brand battery maintainer. The diesel's batteries get hooked up to a Black and Decker maintainer, and they stay in the truck.
Howard and Peggy
"Don't Panic"
jaycocreek
Idaho
Posted: 02/24/21 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Grodyman wrote:
Hi all,
Gman
I have a couple Schumacher chargers also but I went a head and bought a Noco Genius 10a and couldn't be happier,a much better charger...I'm considering there 26a charger..
1994 F-350 DRW /460/k&n intake /415# torque/lance 9.6/Engel compressor fridge/3 gr 27 batteries/Honda 2k/Honda 3K/WH Camo 2250/Reese solid bar extension/Buddy heater/3 inverters//Happi Jack tie downs /Firestone bags/Yamaha Rhino/Winch and Lockers
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 02/24/21 11:43am Link  |  Quote  |  Print  |  Notify Moderator
If you are looking for an old-fashioned mechanical battery charger...
Sorry the government thinks you're too stupid to own one.
I modify MEGAWATT POWER SUPPLIES with my own cables.
Presently modifying a 150-amp MEANWELL for a friend.
We are living in an age of pictures on cash register keys.
