RV.Net Open Roads Forum: Travel Trailers: Another Towing Question
 > Another Towing Question
ttugurl
San Antonio
Posted: 02/25/21 09:19am Link  |  Quote  |  Print  |  Notify Moderator
We just purchased a Puma 28BHSS, which has GVWR 9063 lb. Unloaded Weight 7513 lb.
Our vehicle only towed 9100lbs so we traded and purchased a newer F150 with their newer towing capacities:
3.5L V6 CYLINDER ENGINE
Upgraded Front Stabilizer Bar
Dead Weight Hitch - Max Tongue Wt. (lbs): 500
Dead Weight Hitch - Max Trailer Wt. (lbs): 5000
Maximum Trailering Capacity (lbs): 7000
Wt Distributing Hitch - Max Tongue Wt. (lbs): 700
Wt Distributing Hitch - Max Trailer Wt. (lbs): 7000
3.5L EcoBoost V6 375 @ 5,000 470 lb.-ft. @ 3,500 13,200 3,230
We know F250 would have been a better choice, but it would have been too much truck when we aren't using.
We are new towers. Should we be worried or are we safe? Our RV came with a free hitch but we upgraded for the better sway bar/hitch.
MFL
Midwest
Posted: 02/25/21 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Just looking at YOUR numbers, you have answered your own question!
You will be over the max trailer wt, the max tongue wt.
A 250 would be needed for that trailer, for best towing, and to stay within ratings. Will your new 150 work?? Maybe, but not safely, being that far over ratings.
Jerry
MarkTwain
Northern, Ca. , USA
Posted: 02/25/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Ask yourself some questions to answer your question:
1. What parts of the country are you doing most of your Rving in i.e. mountains with steep grades or mostly flat areas. Do you have an exhaust brake system for mountain grades?
2. how often do you RV? week ends, once a month, do you stay out for weeks or months at a time?
ttugurl
San Antonio
Posted: 02/25/21 10:15am Link  |  Quote  |  Print  |  Notify Moderator
No Mountains! Short 3hr trips to Texas Coast a handful of times a year with longer stays during summer.
I don't understand the numbers. In my mind 13200>7400 by a huge margin.
LadyRVer
Posted: 02/25/21 10:25am Link  |  Quote  |  Print  |  Notify Moderator
If I am reading your post correctly, your Max. towing weight is 7,000 and your trailer is 7513..unloaded?
I tow right at 5,000 with a 1500 and it is doable. At 9,000 #'s, I definitely would want a 250 or 2500. Just my opinion.
MFL
Midwest
Posted: 02/25/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum!
Your numbers are contradicting, and the tongue wt, with WDH seems low. You need numbers for your exact truck, rather than possibly brochure numbers? It was good to upgrade the hitch to better quality and sway control.
Your tire loading sticker, on the door jam will give payload not to exceed XXXX. That and your RAWR number about 4,000? Your receiver hitch, on your truck will give true weights, maybe 600/1200 without/with WDH? There will be a sticker on the receiver.
Your towing wt of 13,200 is not for a high walled big front TT, but for a flatbed, loaded with sandbags or blocks.
A loaded TT, weighing 9000 lbs is a huge load for any 1/2 ton truck! Most, would not want to tow more than a 7,500 lb loaded to camp TT.
Your loaded TT hitch wt should be about 12% of total, so at say 8,500 lbs, loaded to camp, will be 1,020 lbs, plus the weight of the WDH, so near 1,100 lbs on your receiver.
Hope this helps, but keep asking, while providing real numbers from YOUR TRUCK.
Jerry
trailer_newbe
Tucson
Unfortunately Puma trailers are known to be heavy trailers. Anyone mention a 28’ or longer Puma, thats 3/4 ton territory in my opinion. When the trailer weighs considerably more than the truck and will be over 30’ long physics take over, no matter what 1/2 ton you have.
2018 Jayco White Hawk 28RL
ronharmless
The far side
Posted: 02/25/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Go look on the drivers side door, there are two stickers, post a picture of both stickers (Black out the Vin number on the stickers before posting). My F150 would handle that trailer easily without exceeding and of its ratings. Your F150 may or may not, depending on what those two stickers indicate. Any posting which don't take into account what those two stickers say are purely conjecture.
You'll probably have to read up on how to post pictures on this forum also.
ronharmless
The far side
Posted: 02/25/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
trailer_newbe wrote:
... When the trailer weighs considerably more than the truck and will be over 30’ long physics take over, no matter what 1/2 ton you have.
Please tell me about the physics, should be an interesting read. I like to read fiction. Been there, doing that; for about 12 years.
ttugurl
San Antonio
Posted: 02/25/21 10:50am Link  |  Quote  |  Print  |  Notify Moderator
NEW NUMBERS: SORRY, THIS IS FROM EXACT VIN:
Wt Distributing Hitch - Max Trailer Wt. 5000.0 min 12700.0 max
Wt Distributing Hitch - Max Tongue Wt. 500.0 min 1270.0 max
Maximum Trailering Capacity- 5000.0 min 12700.0 max
Dead Weight Hitch - Max Trailer Wt.5000 lbs 5000.0 min 5000.0 max
Dead Weight Hitch - Max Tongue Wt.500 lbs 500.0 min 500.0 max
I'll post pics in the evening! Thanks for the information, thus far.
