RV.Net Open Roads Forum: Travel Trailers: Will water lines freeze?
 > Will water lines freeze?
Rxkjm1
Minnesota
Posted: 02/25/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
We will be heading to Utah (from Minnesota) for a week and Are trying to decide whether we fill our tanks before we go.
The overnight temps for the first 2 nights are forecast to be in the low 20s. After that, it should be above freezing.
I’d we fill our tank, will our lines freeze overnight if the inside of the camper is heated to 65 degrees and it warms up during the day?
Bumpyroad
Virginia
Posted: 02/25/21 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
are all pipes/tanks inside the heated area?
bumpy
Rxkjm1
Minnesota
Posted: 02/25/21 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
The tanks are on the underbody, which is not heated. I’m not really worried about the tanks though because of the volume and small amount of time exposed to low temps.
HappyKayakers
Somewhere in the USA
Posted: 02/25/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on how you're heating the camper. If you're using the furnace and the lines are all in an enclosed underbelly, you should be good. If you're using space heaters/fireplace for heating, that heat will NOT go under the trailer. Remember to leave your cabinet doors open below sinks either way.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Campground Tees
Rxkjm1
Minnesota
Posted: 02/25/21 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advice!
Bishop area, California
Posted: 02/25/21 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
WIthout an enclosed underbelly I wouldn’t chance it.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
valhalla360
No paticular place.
Posted: 02/25/21 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
2 days and it's already winterized...I'd probably leave it winterized until you are clear of freezing (or at least lows in the upper 20's with heat on at night).
That said, it's probably going to be OK. I would try to keep the waste tanks empty at night and the fresh full. What pipes are not in the cabinets? Usually the line from the fresh water goes directly into the interior and then pipes are run in the back of cabinets.
PS: consider running the hot water heater at night.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Bumpyroad
Virginia
Posted: 02/25/21 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I would not leave the fresh tank full. leave a little room for expansion.
bumpy
BarabooBob
Baraboo, WI
Posted: 02/25/21 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Why haul all of that weight 1200 +/- miles? I would never trust weather forecasts to be that accurate. If the forecast is off by 10 degrees, your pipes can easily freeze up. I would drain the fresh tank and blow the lines out with air. Fill. your water tank when you get to camp.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
Posted: 02/25/21 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
“Why haul all of that weight 1200 +/- miles?”
Because you never know, Baraboo.
