RV.Net Open Roads Forum: Fifth-Wheels: Raising our 5er
 > Raising our 5er
klr650goldwing
minnesota
Posted: 02/25/21 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Our 5th wheel rides about 2 inches high in the front. We checked into lowering our 2017 F350 DRW truck, but we can't do that. So, now we are considering raising our 2014 Grand Design Solitude 5th wheel trailer. Have any of you done such a thing to your 5er? What are the pros and cons, dangers, pitfalls etc.
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
RobWNY
Jamestown, NY
Posted: 02/25/21 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
I was 2" nose high and I was able to raise my king pin up a bit since it had another set of holes to utilize. It lowered my nose an inch so I'm still 1" nose high but over a 38 foot length it's not going to cause me to lose sleep.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
work2much
On the Road
Posted: 02/25/21 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Can you adjust the hitch or kingpin and still maintain bed rail clearance? Our solitude is already 13'-5"ish in height stock. 13'-6" is max height in many states. Probably not an issue but something to keep in mind.
Our 2017 Ram has our Solitude pretty flat but it has the factory air that allows some downward bed adjustment to where the truck is level. We have 6 inch of bed rail clearance which so far has been enough.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2400 watts solar. 600ah lithium. Magnum 4000 watt inverter.
lenr
Indianapolis, IN
Posted: 02/25/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Best way to actually know how much raise is needed is to pull the trailer wheels up onto boards until the trailer is level, then measure the boards and rail clearance on the truck. We have 7" rail clearance and there have been times when we were glad that we had it. We added MORRyde SRE4000 rubberized equalizers to our trailer--they raise it about 1 1/4" at the wheels. We also replaced the OEM Chinese tires (235/80R16) with Goodyear Endurance trailer tires in the 235/85R16 size which raises a theoretical .45" at the wheels for almost 2" total. LT tires also come in that size. The SRE4000 is amazing in how it smooths the trailer ride and is just as easy as replacing a solid equalizer. MORRyde recommends on of their X-Factor braces on the center pair of spring hangers when using the SRE4000.
Cummins12V98
on the road
Posted: 02/25/21 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
"Our solitude is already 13'-5"ish in height stock."
Have you "physically measured" your 5er at the highest point? Or are you going by mfg info? I have 3" risers added to my Mobile Suites and I am at 13' 4".
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Old-Biscuit
Verde Valley
Posted: 02/25/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
2" nose high on a 39' 5th wheel should not be an issue
Yes it is good to tow level but at 2" nose high are you experiencing any towing issues?
Chucking, abnormal rear trailer tire wear etc????
US NAVY------USS Decatur DDG31
work2much
On the Road
Posted: 02/25/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yes using 6 foot level off the front AC unit. That's a hitched height. It is a littler lower unhitched.
alboy
Kelowna B.C.
Posted: 02/26/21 05:52am Link  |  Quote  |  Print  |  Notify Moderator
I towed a 36 ft for a number of years 2 inches high,towed great.Then levelled it .In hindsight i felt it towed better in high winds nose high.
Veebyes
Posted: 02/26/21 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Installing the Correct Track system will raise the trailer 3". A relatively inexpensive & easy install.
2007 Alpenlite 34RLR
ford truck guy
Pennsylvania
Posted: 02/26/21 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Take the entire set up to Sergio at Morryde and have them put the IS on ! They will make sure your truck and trailer are 100% level before leaving.. AND you will have arguably the best suspension on that fiver....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
 > Raising our 5er
