RV.Net Open Roads Forum: Technology Corner: Internet speed
 > Internet speed
monkey44
Cape Cod, MA and Central Fla
Posted: 02/26/21 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Can any one clarify what this means ... I see it as 100 divided by 5, which would be 20Mbs ??? But monkey mostly clueless about tech. And it generally takes 25Mbs or higher for 4K Streaming, unless I'm truly out to lunch here ... probably a fact [emoticon] Thanks M44
Comcast ISP: Performance Currently at 100/5Mbs
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
phil-t
Ogdensburg, NY
Posted: 02/26/21 06:07am Link  |  Quote  |  Print  |  Notify Moderator
100 Mbs download/5 Mbs upload.
2010 Winnebago Vista 32k on a 2009 Ford F53 22k chassis
Bill.Satellite
Full-timer
Posted: 02/26/21 06:18am Link  |  Quote  |  Print  |  Notify Moderator
There it is! First answer. Done.
Any other questions?
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
fj12ryder
Platte City, MO
Posted: 02/26/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
The only question would be bits or bytes? Small "b" so it's bits.
Howard and Peggy
"Don't Panic"
BobsYourUncle
Calgary Alberta Canada
Posted: 02/26/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Bits and bytes can be confusing. Bits are smaller than bytes.
It can also be misleading in terms of data download.
If someone tells you that you have xx number of megabits speed, it is less, or slower than megabytes speed. 8 bits to a byte.
Confused?
Try this - Bits vs Bytes
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
wildtoad
Blythewood, SC
Posted: 02/26/21 08:57am Link  |  Quote  |  Print  |  Notify Moderator
And does it not require additional bits to be added to the data for communications purpose? And don’t forget the terms half byte and nibble.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
valhalla360
No paticular place.
Posted: 02/26/21 09:35am Link  |  Quote  |  Print  |  Notify Moderator
The days of 1200 baud modems are long gone outside a few specialty uses.
No one is advertising consumer internet services based on those units. So while technically different, other than to be contrary, there is no confusion.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
fj12ryder
Platte City, MO
Posted: 02/26/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
"No one is advertising consumer internet services based on those units."
What units are you referring to? Internet speeds are indeed advertised as either MBps or Mbps, just depends on whether the advertising unit knows the difference.
Would you rather have 10 MBps or 10 Mbps? It does make a difference.
NamMedevac 70
Reno
Posted: 02/26/21 11:52am Link  |  Quote  |  Print  |  Notify Moderator
All the internet speed test sites I have used use Megabytes as standard for measuring speed. Good enough for me.
monkey44
Posted: 02/26/21 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Our community is contracting Comcast for internet - it says we will get service at 100/5Mbs -- that's exactly how it's written ...
So I wondered what it actually means - especially with 4K videos etc. I'm not a fan of Comcast, not very good customer service ... But I only have one vote, just want to make sure it's fast enough for every one that wants HS service. I'll be outvoted, but it's the best pricing, and we have 1500 homes. We will also get it in the Rec areas, and in our RV park.
Our underground cable has been under ground for 23 years. [emoticon]
Comcast says it will install new Fiber Optic cable to every home and our rec areas ... and tells us 100/5Mbs our ISP speed. Sounds like it will do it ... Thx guys M44
 > Internet speed
