RV.Net Open Roads Forum: Class A Motorhomes: SMI Air Force One install
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > SMI Air Force One install
rvroamerrandy
Yorba Linda CA
Posted: 02/26/21 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Good Morning al. Just purchased the air force one proportional braking system. My question is do I need to dump the bags and jacks prior to cutting my supply and metered lines on the coach? I have a 2011 Winn Journey on a Freightliner chassis. the coach is too low to leave on the ground without the jacks. I am a big guy so either jacks up or i pull it up on blocks? need some advice here. I understand i need to pump brakes 3 or 4 times to release the air in system but not sure if this effects jacks? I appreciate some direction here if anyone has some. My fear for some reason is being under the coach, cutting the lines and the coach starts rolling.
2011 Journey 40U
2020 Chevy Trail Boss
Randy
* This post was edited 02/26/21 07:27am by rvroamerrandy *
CA Traveler
The Western States
Posted: 02/26/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
You are courting potentially extreme danger! The chassis needs to be throughly supported by mechanical jacks period. People have been killed from falling vehicles.
Based on your questions you should give very serious thought to having the unit installed in the MH.
2014 Grand Cherokee Overland
Bob
67Cutlass
Fulltiming
Posted: 02/26/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
To answer the OP's question. Your air bags and jacks are not in any way connected to your air brake system. No you do not need to dump the bags and jacks.
Just keep safety in mind when doing this.
2012 Phaeton 40QBH
2015 Jeep Cherokee
SMI Air Force One
Retired USAF - CEVG and AFTAC
Member of Tiffin RV Network Forum
Monterey, California
Posted: 02/26/21 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Danger lurks under an RV, truck, car etc. Be careful.
CA Traveler
The Western States
Posted: 02/26/21 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yes but the AF1 unit in the motor home requires both the brake line and a supply line meaning the main tank will be empty. Perhaps just one step closer for the air bags to become deflated.
67Cutlass
Fulltiming
Posted: 02/26/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Even if you empty both air tanks that will not dump the air out of the inflated bags.
The bags are not dumped until you level the mh using the automatic leveling system or manually dump the air bags.
With the suspension fully inflated you can still manually extend the jacks and keep the bags inflated.
CA Traveler
The Western States
Posted: 02/26/21 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Good to have more detail on the operation.
But what does this have to do with safety regarding being under the MH with just the jacks and air bags?
rvroamerrandy
Yorba Linda CA
Posted: 02/26/21 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
WOW, that stirred up a whole slew of conversation. I Just want to make sure that safety s first. I'm not much worried about the installation process other than the cutting of the brake line. I guess the real question I should have asked is, is the emergency brake anyway connected to this supply line or metered line that I will be cutting? I appreciate everyone's comments and I look forward to more replies.
Thanks,
Randy
CA Traveler
The Western States
Posted: 02/26/21 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Emergency air brakes are different. A big spring applies the ebrake when there is no air pressure. When you release the ebrake switch you are actually sending air pressure to the ebrake to pull the big spring back and disengage the ebrake.
ie Think losing air pressure for some reason to the point where the service brakes don't work and then the ebrake will be applied.
robatthelake
Vancouver Island
Posted: 02/27/21 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
The auxiliary system airline should be connected to one of the unused outlet points on the rear air brake manifold!
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
