RV.Net Open Roads Forum: Toy Haulers: Gen octane recommend
Search only in Toy Haulers
 > Gen octane recommend
sin cal hd
Hooligan #109
Posted: 02/26/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
Curious if anyone has put different octanes in their tanks? I've usually ran 87 but I've put 89 in too. But I'm not sure if that's maybe what's caused my gen to run hot and possibly overheat and shut down.
Anyone have experienced issues running a different grade?
2015 2500 Ram Mega Cab 4x4
2017 Wolf pack 325
Wife and 2 little boys
2 golden retriever pups
dedmiston
The West
Posted: 02/26/21 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
I run exclusively 89 in ours, because our bikes and SxS require 89 and I don't want to deal with two grades of fuel.
No problems with ours.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
sin cal hd
Hooligan #109
Posted: 02/26/21 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
That's what I do as well. It just crossed my mind that maybe the higher octane was causing issues
dieseltruckdriver
Black Hills of SD
Posted: 02/26/21 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
I only use 91 ethanol free in both of mine, and have never had a problem.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
dedmiston
The West
Posted: 02/26/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
I meant to say 91. I drive a diesel, so the choices at the gas pump are foreign to me. [emoticon]
Premium.
arhayes
Posted: 02/26/21 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
I run 87 octane non ethanol as recommended. I do add SeaFoam regularly and Stabil when I fill up in colder temps. Worked well for 7 years and starts and runs well every time.
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
MFL
Midwest
Posted: 02/27/21 07:08am Link  |  Quote  |  Print  |  Notify Moderator
This is the best choice, if available!
Adding ethanol, will cause a more lean condition, and can cause more heat, under load. The OP may have used a higher octane 89 fuel, that contained more ethanol, and caused over heating, of his small gen engine, while under max load?
Jerry
deltabravo
Spokane, WA
Posted: 02/27/21 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Ethanol free only in my generators and all power equipment and motorcycles, which is Premium (91 octane)
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
jdc1
Rescue, Ca
Posted: 02/27/21 08:21am Link  |  Quote  |  Print  |  Notify Moderator
My Honda 2000 uses 87 octane. Started (before I sold it to upgrade) on first or second pull for 20 years. Why waste money on premium fuel?
lamopar
Oregon
Posted: 02/27/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
We run 91 ethanol free and learned this from our previous toy hauler after destroying the carb with regular ethanol fuel. Our new toy hauler only has one fuel tank so we fill our ATVs and run the gen on the same fuel. No problems with our on board Onan nor the portable Honda.
