RV.Net Open Roads Forum: Tech Issues: LiFePO4 - SOK or Renogy.
 > LiFePO4 - SOK or Renogy.
Page of 11
Almot
out there
Posted: 02/26/21 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Not looking for a big bank or high charge/discharge currents. Don't need charging below freezing. In Canada things become difficult/expensive.
Narrowed down to these 2:
1)SOK, 100AH, $CAD 975 +$5 S/H. Takes both series and parallel connections. Metal case, 4 plastic-looking cells inside, impressive looking BMS and wiring. Claims "replaceable BMS or cells" - and it is indeed possible to take apart and service only I have no idea where one could get those cells or BMS. Available at amazon.ca straight from China. 7 years warranty. Support reportedly exists. SOK, 100AH
2) Renogy, 100AH, $CAD 850, free S/H. Plastic case contains metal enclosure inside with many pouch cells, - so not much serviceable. Takes only parallel connections, but I don't need series anyway. This is a sale, Amazon have it at $CAD 1,200. 7 years warranty. Support exists and is spotty. Renogy make their own solar panels but I doubt they make batteries or electronics, must be a relabeled Chinese product: Renogy, 100 AH.
Importing Battleborn from the US at $CAD 1,200 + unknown S/H is out of my range. Assembled from Chinese cells like all others, though they do assembling work in the US. 10 years prorated warranty.
There is also Lifeblue at $CAD 975 + unknown S/H, maybe will look into those too - their BT monitoring is a nice feature. No idea what's inside. Lifeblue, 100AH
* This post was edited 02/26/21 04:51pm by Almot *
Itinerant1
Itinerant
Posted: 02/26/21 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
If I was going to buy a dropin battery it would be Lifeblue. Choice of batteries with or without heating pads, bluetooth, with the ability to see individual cells (prismatic), various AH size of batteries, plus I've read enough good thing of folks using them for a couple years now.
12v 500ah (5,120Wh usable), 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 1,600+ cycles.
StirCrazy
Kamloops, BC, Canada
Posted: 02/27/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
LiFePo4 batteries on Amazon
here is a link for them on amazone, price has droped like crazy reciently. Pianotuna even posted a sub 500 buck one from a place in Sask if I recall right. if you handy and want a bigger capacity you could build them yourself using prismatic cells.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
pianotuna
Regina, SK, Canada
Posted: 02/27/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Hi Almot,
If I were going to buy LiFePo4 in Canada, I'd likely purchase here:
https://www.ablithium.ca/
These appear to be the cheapest anywhere.
If you are in Western Canada it might even make a nice trip?
Regards, Don
pianotuna
Regina, SK, Canada
Posted: 02/27/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Please Steve,
Don't lumber folks in SK with a company from Alberta. (that's the home of extreme right wing).
They seem to have very little in stock. I think they want an order and deposit before they bring the batteries to Canada.
* This post was edited 03/04/21 08:57pm by pianotuna *
Almot
out there
Posted: 02/27/21 09:49am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi Almot,
Thank you, Don. May I ask why - other than the price which is indeed low, perhaps the lowest I've seen anywhere.
I forgot to mention that SOK reportedly have prismatic cells. They don't say this on their website but there was a specs sheet posted by retailer.
Renogy pouch cells don't inspire confidence, though they enclosed it in metal box before enclosing the whole thing in plastic black box.
pianotuna
Regina, SK, Canada
Posted: 02/27/21 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Almot LiFePo4 are pretty much useless to me. The only decider is price.
I believe the major factor in LiFePo4 is the battery management system. They jump through all sorts of different hoops. Nailing down what they actually do may be difficult research. I'd want to know what the cut off is for temperatures both low and high, and whether they limit the discharge rate. Some do 100 amps demand, others are 150 amps per 100 amp-hours of storage, still others are 'no limit'.
I also don't appreciate LiFePo4 living longest at 50% state of charge when in storage. It would mean turning off the solar--then going over and turning it back on a week before a trip. It almost makes solar redundant, kinda, sorta?
* This post was edited 02/27/21 11:27am by pianotuna *
dieseltruckdriver
Black Hills of SD
Posted: 02/27/21 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I believe the major factor in LiFePo4 is the battery management system. They jump through all sorts of different hoops. Nailing down what they actually do may be difficult research. I'd want to know what the cut off is for temperatures both low and high, and whether they limit the discharge rate. Some do 100 amps demand, others are 150 amps per 100 amp-hours of storage.
We have recently started using ReLion batteries at work. We switched from lead acid to LiFePO for weight savings. We haven't been using them long enough to have any helpful input, but this company does offer a low temperature version.
Pianotuna, I have some of the same misgivings about them as you do, but I really like the weight savings. I have also wondered about the solar in the winter storage issues.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
phemens
Montreal, Canada
Posted: 02/27/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
If you want to buy in Canada, I bought from this company 2 years ago (total of 6 100ah batteries), and dealt with the guy who runs the outfit, very accomodating and full of info (he's an electrical engineer). He helped me figure out all the correct settings for my MPPTs and charge controller.
Lynac Lithium
As an aside, the storage of LiFePo4 batteries at 50% is meant for long-term storage (i.e. over the winter), not a problem at all if it's a matter of weeks.
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
pianotuna
Regina, SK, Canada
Posted: 02/27/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
phemens,
Nice size system!
Page of 11
