RV.Net Open Roads Forum: Truck Campers: Trimming down tie downs to fit
 > Trimming down tie downs to fit
F-350shortBed
Natividad Medical Center
Posted: 02/28/21 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
I had purchased some longer torklift tiedowns to fit my frame mounted tie down points. I also acquired some fast guns with the purchase from my TC.
I want to trim the bottom hook portion to fit the fast gun uppers.
Does anyone out there have a system for measuring and cutting them to fit?
Thanks, everyone.
joerg68
St. Ingbert, Germany
Posted: 02/28/21 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I have no useful answer to your original question.
But why are the Fast Guns too long? You have a normal truck, normal
camper, Torklift tiedowns - everything should fit like it usually does?
Do you have a picture?
d3500ram
Colorado
Posted: 02/28/21 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Joerg... something does not seem right... we need more info.
My guess might be that OP is trying to use fastguns on Hippi-Jac mounts????
F-350shortBed
Posted: 02/28/21 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased a TC that was mounted on a happijac setup. The seller included the fast guns which were short for the Happijac points on his truck.
My truck has torklift tie down points. I had also purchased torklift XL spring mounted turnbuckles which have a longer hook that attaches to the tie down point. I purchased these prior to the TC.
I would like to use the longer hook from the XL turnbuckles to screw into the fast gun upper so I don’t have to manually screw them tight every time I remove the camper and put it back on the truck.
When I mate the longer hooks with the fast gun uppers they are too long.
I can post a pic on Monday. Maybe the TC seller’s attachment are not fast guns but work in the same manner?
Posted: 02/28/21 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
So, same thread but the threaded end is too long?
Yup chop ‘em. Just leave enough length on the threaded part.
I’ve never been able to cut the same piece longer the second time! Haha
2017 Heartland Torque T29
AISURFFISH
BERLIN MARYLAND
Posted: 02/28/21 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
That's funny right there.. like we can post photos in here...
Ha
Ha
Ha...
2017 F350 6.2L Crew Cab
Arctic Fox 990 2021 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF FISHING RODS TICA TO BE EXACT
d3500ram
Colorado
Posted: 02/28/21 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Use this site to drag n' drop and then post the resulting string:
photo posting
JimK-NY
NY
Posted: 02/28/21 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
As I understand the issue, your fastguns are too short. I had something similar happen. I raised the camper an inch more so that I had better clearance between the camper overhang and the roof of my truck. That extra inch was more than the capacity of my fastgun so I just used a chain repair link to regain some length. If more length is needed you could use the repair link to attach as many links of chain as needed.
joerg68
Posted: 03/01/21 12:26am Link  |  Quote  |  Print  |  Notify Moderator
OK I think I get it now.
You could lengthen the (too short) Fast Guns with a section of chain* - Thats what I do as I bought two of the short ones in error back in 2009. I had HJ bumper buttons in the rear on our old truck. Found out, the short Fast Guns are for the front tiedowns. We have TL tiedowns all round on the new truck.
Do you have four short Fast Guns?
You could try to sell both sets and buy the correct length Fast Guns.
Or you could probably try to combine both sets, as you described in your question. The Fast Guns disassemble easily, so you should be to find out how long the hook section needs to be / where the nut is that it bolts into inside the housing. At least I think I remember that mine came dissembled from the factory. Unscrew the hook part until it comes loose, then the retainer nut is free inside the housing. There is a plastic cap on the upper end of the housing that you can remove. The loose retaining nut just comes out at the top end. At least I think that is how mine work. I have never used the standard turnbuckles, but I imagine they disassemble just as easily.
* if you do this, you need chain with welded links and one threaded chain link for each tiedown. At the time, I think TL had included the chain/link hardware with the tiedown kit.
* This post was edited 03/01/21 12:51am by joerg68 *
Bert the Welder
Van. Island
Posted: 03/01/21 01:07am Link  |  Quote  |  Print  |  Notify Moderator
Maybe hang the FG in the TC eyelet and hook your long rod into the TL eyelet. Hold the two inline and eyeball where the nut in the FG lines up with the long rod and mark or put a piece of tape on the threaded rod. Cut a couple inches longer for FUBAR factor. (Provided my dyslexic brain is understanding you correctly. I'm reading it as when you screw in the longer XL hooks, they are so long they hit the end of the inside of the FG body before they are short enough to get in the hole of the tie down)
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
