RV.Net Open Roads Forum: U.S. Highway 17 Coastal Hwy from Savannah GA thru S Carolina
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > U.S. Highway 17 Coastal Hwy from Savannah GA thru S Carolina
cpd520
On the road
Posted: 02/28/21 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
How is U.S. Highway 17 Coastal Highway from Savannah GA through South Carolina? I'm Driving 37" Class A with toad. We would be passing through mid March.
We have driven Hwy 1 up the west coast without issue. Similar drive?
Jack and Nina
DrewE
Vermont
Posted: 02/28/21 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
It should be no problem at all for you. I took it going south several weeks ago with a 32' class C, and I don't recall any real difficulties or hardships.
The road is much less curvy and far more inland than CA route 1. You don't have ocean views, and indeed are generally a few miles or so from the shore. It's generally scenic-ish, but not spectacular in the way that much of CA 1 is.
QCMan
Independent Republic of Horry
Posted: 03/01/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Just did that exact route coming home from Tybee Island. Worst part of the trip is the lights going through Mount Pleasant but it is not too long and you are out of it. Georgetown is better than it has ever been in a long time. Nice run from there to Murrells Inlet and then you start getting into the Grand Strand congestion. Not a bad road at that point just a bit crowded.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
cpd520
On the road
Posted: 03/01/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thx for the replies.
Merrykalia
Appalachian (apple at chun) Mtn in the GREAT SW Va
Posted: 03/01/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Never driven up the left coast, but have driven up both 17 and 13 on the east coast. Several times while towing our 35' TT and also not towing, we took it because I-95 was a parking lot and it was such an enjoyable drive, we started using it exclusively.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
