RV.Net Open Roads Forum: Truck Campers: New Cooper tires behavior
 > New Cooper tires behavior
gitpicker2009
texas
Posted: 03/01/21 07:40am Link  |  Quote  |  Print  |  Notify Moderator
I just installed 6 new Cooper tires on my Sterling 4500. These are the 19.5s.
I was replacing my old Dynatracs. The Dynatracs only had about 12K miles, but were 8 years old. I only use the truck for TC stuff generally. I never had a problem with the Dynatracs but the 4 rear wheels were "drive" wheels, different from the front "steer" wheels.
Now,at the advice of the tire dealer, the new Coopers are all steer wheels, so that I can rotate all the tires as needed. BUT... the truck now feels like I'm floating on a bubble. It's the only way to describe it. And, when you hit the brakes it feels VERY unstable. I've got the tires set at the same 80 PSI.
The dealer said that's normal and that the new tires would feel a bit "squirrelly" until I put about 500 miles on them.
Has anyone else dealt with this and if so, did it improve? I find it strange that the more expensive Cooper tires don't seem to drive as well as the cheap Dynatracs.
Thanks for any and all advice as always.
jimh425
Western MT
Posted: 03/01/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
I believe it is “normal” for 19.5s to move around during break in and track groves in the road.
Buzzcut1
Norcal
Posted: 03/01/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
I hated the "Steer" tires they floated and grab lips. Switched to Drive tires all around and the issue went away. That was Toyo steer. switched to Roadmaster drive tires by Cooper.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Yosemite Sam1
Under the pines.
Posted: 03/01/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
That's some scary sh!t.. I wonder how it will behave and what will happen In badly constructed highways.
pianotuna
Regina, SK, Canada
Posted: 03/01/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Tire pressure too high may have the same effect, especially on the front wheels.
Regards, Don
opnspaces
San Diego Ca
Posted: 03/01/21 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Every time I get new tires, no matter the brand, it feels like I'm driving on ice. The last time which was only a few months ago I was very nervous on the freeway as it really seemed to skip and skate around. After a few days the feeling was gone and it was back to driving like normal.
One thing that may be helpful is to realize that your new tires will behave differently than your old tires. When you drive you subconsciously move the steering wheel back and forth to correct for the road. Since your new tires will react differently than the old tires, the corrections you need to make are going to be different. This means that the speed and force that you apply to the wheel is going to be different and you might in fact be exacerbating the behavior because you are still steering for the old tires.
Try taking it down the highway or freeway with a very light grip in the wheel. Let the truck drift a bit and use very small movements to keep it in line. Once you learn the idiosyncrasies of the new tires I'll bet you find them just as rock solid as the old.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
markchengr
Seattle
Posted: 03/01/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Both times with new 19.5's, they felt kind of drifty for nearly the first 1,000 miles and then it went away as they wore in. They're real stable now. I've had Hankooks and now Toyos. They drive pretty much the same. Mine were all aggresive tread. I'm on my second set now with a total of 205,000 miles.
Buzzcut1
Norcal
Posted: 03/01/21 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
80psi is about the minimum pressure that you can run 19.5s at without losing the bead
bwlyon
64633
Posted: 03/01/21 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Totally normal till you get some miles on the tires.
gitpicker2009
texas
Posted: 03/01/21 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Is 80 PSI really considered low??? What do you recommend?
