RV.Net Open Roads Forum: General RVing Issues: Odor control for plastic urinal installatoon
 > Odor control for plastic urinal installatoon
mobeewan
Hampton, Va
Posted: 03/01/21 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
I just purchased anEco Tek Urinal and will be installing it in my work shop when it is built connected to a jug or 1-1/2 inch line buried and connected to my newly planned buried dedicated TT dump line running to my sewer clean out.
I later plan on using another Eco Tek Urinal with my custom trailer build i plan on doing with the urine going to a urine only waste tank or jug. I will be able to hang it in the step in shower or hang it on the side of the trailer with a shower curtain or shower tent for privacy. Either way i will be able to connect it to the dedicated urine tank from either location.
From what i have seen, with composting toilets a small amount of white vinegar is added to the urine diverter tank and a spritz of white vinegar from a spray bottle is used to spray the toilet surfaces after making deposits.
For those with experience with composting toilets, is this all that is needed for complete odor control and cleaning or should i add anything else with the vinegar in the spray bottle? I am familiar with the geo method for traditional TT black tanks holding "mixed" waste.
And please, don't anyone start a composting vs traditional TT toilet and black tank war. Moderators please delete any of those comments.
Bishop area, California
Posted: 03/01/21 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Give the white vinegar a shot IMO.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
DrewE
Vermont
Posted: 03/01/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Venting the waste tank to the outdoors would, I suspect, help a lot with controlling the odor indoors--especially if you use a trap or other seal setup like commercial waterless urinals. (Often, they have a trap that is sealed by some non-water liquid that is less dense than urine, so that it floats on top of the urine in the trap. There are various designs, though, including some that operate on different principles.)
mobeewan
Hampton, Va
Posted: 03/01/21 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
The tank will be vented like they usually are through the roof and there will be a loop in the tubing between the urinal and urine tank to act as a trap to keep tank odor from coming back into the trailer.
I'm looking at completely neutralizing the stink of the urine and am trying to see if the vinegar by itself works or if i need to add anything else. I'm also trying to keep as much urine as possible from the porta potty i plan on using with the trailer.
NRALIFR
Truck Camping Out West
Posted: 03/02/21 03:27am Link  |  Quote  |  Print  |  Notify Moderator
Vinegar, being an acid, is commonly used to neutralize the odor or urine. Urine gets most of its odor from ammonia, which is highly alkaline.
A mixture of 25-50% vinegar with water should do it.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
valhalla360
No paticular place.
Posted: 03/02/21 04:37am Link  |  Quote  |  Print  |  Notify Moderator
We always just used a spray bottle of water...never had an issue with odor.
Never heard of the vinegar solution. Some had suggested a little sugar in the jug but we never found it necessary. I would think with a remote tank in the underbelly, it would be even better isolated.
Our jug was about 2.5gal and it had to be emptied at least every other day.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
FlatBroke
CO/AZ
Posted: 03/02/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Use one of those urine jugs like the give you in the hospital. When nature calls use it. Pour it out when you go inside. Works for me.
Hitch Hiker
"08" 29.5 FKTG LS
CavemanCharlie
Storden,MN
Posted: 03/04/21 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
I may misunderstand. (I do a lot) But, if you don't use a water trap in the drain line to the urinal then isn't the odor from the RV clean out line in your shop or the odor from your holding tank in the camper going to come back up through the line and smell bad ???
I don't mean to offend or anything but, isn't 70 dollars for a plastic funnel in the wall of your shop kinda expensive ?? I have a friend that just uses a regular cheap plastic funnel in the wall of his shop.
mobeewan
Hampton, Va
Posted: 03/04/21 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
For trailer or shop I will loop the line to create a trap. For either use I'll have a shut off valve especially for the trailer when towing, so I dont get any splash back from the tank.
The price is $69 Canadienne and aboot $55 Merican.
* This post was edited 03/05/21 11:49am by mobeewan *
