RV.Net Open Roads Forum: Any option for re-filling MH Propane Tank from Small Tank?
 > Any option for re-filling MH Propane Tank from Small Tank?
johnhicks
Wandering below the Gnat Line
Posted: 03/04/21 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Residential and "recreational" propane are priced differently; that's probably what's going on.
-jbh-
crawford
Dandridge Tenn.
Posted: 03/05/21 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Have a home with a 1,000 pound tank next store have a 5 th wheel with a 500 pound he have poundage charge is the same per pound propane is just price very high the N Gas. the have a delivery charge on my bill and his. 75.00 more crooks with out guns. This year I dumped the got a Heat Pump.
Change from a c class to a A class Georgetown 07 triple slide
pianotuna
Regina, SK, Canada
Posted: 03/05/21 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Because I have a 'fixed' tank, if I buy propane at a gas station, I end up paying road tax for it.
Regards, Don
Rice
Wandering
Posted: 03/22/21 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
BTW, you might not need to install an Extend-a-Stay to use one of those Blue Rhino-type cylinders. We don't have room to carry one of those cylinders but we sometimes stay at a place where a guy has one for us to use, and this is the only time we ever do that. We have it on the ground next to the onboard propane tank, and plumb into it directly by detaching the line coming out of the onboard tank and moving it to the cylinder.
malexander
Oklahoma City, OK
Posted: 03/23/21 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
mowermech wrote:
Many years ago I worked for the Forest Service burning logging slash piles. We used back-pack propane torches. When the torch bottle was empty, we returned to the pickup and filled the bottle from a 100 pound cylinder in the back of the truck. Liquid transferred from the big cylinder to the little bottle using only the pressure in the big cylinder. Of course, we had to open the "80% valve" on the little bottle to relieve the pressure so it would fill properly. As soon as we got liquid from the "80% valve" we shut off the valve on the big cylinder, shut off the valve on the little bottle, disconnected the hose, connected the torch and went back to lighting fires.
This long dissertation is just to illustrate that it IS possible to transfer liquid propane without a pump. Is it "safe"? Probably not. Anytime a flammable gas is vented to the atmosphere it can be dangerous.
Good luck.
I made up a hose and filled my Class C motorhome tank like this from a full 100# tank. I'd turn the 100#er upside down so I would get liquid out of it. I'd do it on my driveway on a windy day so the vapors would blow away quickly.
2007 Fleetwood Bounder 38N 330 Cat DP, 2008 GL1800 Goldwing, Cessna 150 & 172, Rans S6S Coyote, Vans RV9A. Lifetime NRA, EAA, Good Sam member
craz z
Montana
Posted: 03/23/21 11:47pm Link  |  Quote  |  Print  |  Notify Moderator
I've studied this subject extensively and have finally come up with solutions to filling the on-board tank.
1 filling Station easiest most expensive way to fill.
2 extend a stay easiest for Mobil use still very expensive as the 20 pounders are not filled all the way so 20$ gets you 70-80 of max fill for liability.
3 diy liquid transfer need a pol to pol fitting with acme 1 3/4 adaptor. liquid forklift tanks are ideal. 20pounders need to be upside-down for liquid and expect delays with opd device. boiling water is necessary for creating pressure differential.
this can be super cheap if filling your pounders off a bulk tank otherwise not worth it extend a stay still wins. Cost is 60 for acme fitting 60 for pol to pol. 120 total
4. The ultimate cheap way buy an adaptor that attaches to the wetleg of a huge tank still need to buy the acme 1 3/4 adapter. Boiling water poured on bulk tank starts the transfer. Open spitter til liquid comes out done. And yes if it's a modern propane tank with a rego valve it will dispense liquid propane as long as hot water is applied to the bulktank to start the transfer.
Wetlegs are on all tanks to pump out liquid for large tanks to be transported safely. The bobtail trucks that fill your house are built to withstand a major impact in a crash your home tank is not thus the need to empty them. Propane is moved around in its liquid state only.a pump is ideal if your a propane dealer only as they are easily 10k for a pump setup.
Now for safety. Obviously this can be dangerous but most injuries are not from explosions rather from frostbite. propane boils to a gas at -44f so gloves an glasses are necessary. Pent up vapors are clearly an accident waiting to happen wind is your friend congested areas like a campground not the best idea. No electronics or hot rigs as u do need to release a little vapor.
The wetleg kit is 200$ plus 60 for the acme adapter.
Being remote with access to a bulk home tank an limited filling stations over an hour away have forced me to find an alternative that works.
You always run out or low when it's hard to find a station. 20pounders are everywhere and are probably the easiest safest way but absolutely u can fill your on-board tank with bulk fuel for a fraction of the cost. I did this more out of convenience then cost as there is a minimal risk an upfront cost but to be able to fill any propane container at any time without having to plan an carry tanks an hour to a station is priceless.
This isn't for everyone an certainly comes with risks, but if you do your homework and follow safe procedures it's very safe.
JaxDad
Greater Toronto Area
Posted: 03/24/21 05:51am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
Don, check with Finance Sask. on that, we routinely submit our receipts for gasoline & propane purchases here and get a refund on the road taxes for fuels used strictly for “off road use”.
pianotuna
Regina, SK, Canada
Posted: 03/24/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
JaxDad wrote:
pianotuna wrote:
Hi,
JaxDad,
Thanks for the heads up. As I attempt to run 100% electrically--I only buy about one tank per year.
Ray,IN
IN, USA
Posted: 03/27/21 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
Good luck.
That is exactly how the adapter kit to refill 1# cylinders work: [image]
And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
