Gator398
Oklahoma
Is it possible, to make a dually truck not shake like an earthquake on expansion joint roads when the trailer is off???!!
I have read about the kelderman 4 link or whatever, is that our only option?
2021 Flagstaff Micro Lite 25BRDS
2011 Ram 3500 DRW Laramie Longhorn 6.7L
MT BOB
Montana
Are you 12?
BenK
SF BayArea
All things will vibrate from some sort of input. When the input harmonic matches the thing’s natural harmonic and if the input continues to input, the thing will vibrate more within the same frequency.
Your running over the expansion joints sets up an input to your truck. Your speed dictates the frequency of the input to your TV.
Slowing down and/or speeding up will change the input frequency to your truck.
As for you trucks harmonic...the things that are part or contribute to its harmonic are the tires, suspension (shocks, bushing, shocks, architecture, etc), the body bushings to frame and a big ETC.
The Kelderman suspension you mention changes the suspension architecture and the air bags adjust what the input’s amplitude & suspension response...AKA tunes the suspension harmonic
Other than changing your speed, changing the tire PSI changes its harmonics, change the shocks and can go either way...more or less dampening, and everything else in that food chain.
Easiest and lowest cost is changing your speed...
-Ben Picture of my rig
Beverley&Ken
Tottenham,Ontario
I'm not a truck person, but read your owners manual and/or door sticker for tire pressure, empty and loaded. If they are overinflated for the load they are carrying, you will get the ride you are describing. Best would be to get the truck weighed fully loaded with trailer, front and rear axle plus trailer axles. Then have the truck alone,as your daily driver weighed, again axle weights.
Then use the tire manufacturers chart for your particular tire to see the recommended pressure for each tire/axle. You might get a smoother ride for next o $0.00
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Concrete roads? Nope, but it should be worse with the trailer on.
Just Rough riding? Lower tire pressure.
Groover
Pulaski, TN
I got a very noticeable ride improvement on my F250 by switching to Rancho 9000 shocks, both empty and loaded. I like being able to adjust these shocks for the load. Others here like Bilstein shocks. I haven't tried them.
Tvov
CT
MT BOB wrote: Are you 12?
What does this question relate to?
2008 F-250 CrewCab 5.4L,
eHoefler
ozark mountains
I reduce my rear tire pressure from 80 psi to 40 psi when I am not towing the fifthwheel
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
wildtoad
Blythewood, SC
Tvov wrote: MT BOB wrote: Are you 12?
MTBOB joined yesterday. I’ve read two of his posts and each one seems to be demeaning to the OP.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
rhagfo
Portland, OR
eHoefler wrote: I reduce my rear tire pressure from 80 psi to 40 psi when I am not towing the fifthwheel
You do realize that you only need 65 psi in your rear tires on a DRW to get to max axle weight rating of 9,750#.
Even that 40' Landmark is not going to put at max rear axle rating. I have seen them run as low as 35 psi unloaded.
