RV.Net Open Roads Forum: Travel Trailers: Trailering
 > Trailering
paulfredricks
CT
Posted: 03/03/21 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
We just picked up our new camper and towed it back from Ohio to Connecticut. Smooth trip the whole way.
Our old trailer was 24'. This one is 32'. I knew it was going to be a bit different due to the increased size, but I was caught off guard by how interesting it can be getting in and out of a gas station.
Any tips from you vets out there who are pulling bigger units? Are there certain things you look for when it comes time for a fill up?
Thanks!
2004 Starcraft 215SSO
2014 GMC Yukon XL Denali
Gdetrailer
PA
Posted: 03/03/21 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Skip stations that have islands arraigned so traffic heads toward the station..
The illustration below should be helpful..
Often that results in extremely tight turns to get around the islands without hitting the station store.. Not to mention there is often a lot of vehicles parked in front of the busier stations and high amount of traffic to dodge.
Something else to consider, you have to be aware of the steepness of the stations entrance and exits, longer trailers will bottom out much easier than short trailers.. So you need to watch for stations that have a gradual entrance and exit pitch.
I have run into a few that hit the tongue jack AND the rear drag bars, scrapping both times.. Don't want to high center the trailer and be stuck half in traffic..
1320Fastback
Vista, Ca
Posted: 03/03/21 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
I look for Shell stations. They usually have higher prices and are not crowded because of that.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
time2roll
Posted: 03/03/21 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
I try to avoid gas in the city and watch for truck stops out on the highway. Otherwise I just wait my turn at the most accessible slot. If I unhitch for the night I make sure to be topped off for leaving.
675w Solar pictures back up
afidel
Cleveland
Posted: 03/03/21 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting, almost all of the stations I look for are like your X diagram, but I look for ones with sufficient room to make it easy, Pilots, Flying J, Sheetz, Racetrack, etc where there is 3-4 car widths between the overhang and the back of the cars at the convenience store. I pre-select my stops at ~170 mile intervals and have a backup to each one in case I can't get to my primary for some reason.
My biggest tip is use Google maps in terrain mode and street view mode to look at the stations ahead of time.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
Rover_Bill
NE. Ohio
Posted: 03/03/21 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
X2 for street view in Google maps!
gbopp
The Keystone State
Posted: 03/04/21 04:16am Link  |  Quote  |  Print  |  Notify Moderator
X3 for street view on Google Maps.
valhalla360
No paticular place.
Posted: 03/04/21 04:37am Link  |  Quote  |  Print  |  Notify Moderator
I often find the ones you show as good...undesirable. That configuration is often used when the station has limited land to work with.
On the other hand, most modern stations with lots of space, use the style...you find undesirable.
Thoughts:
- Fill up before hooking up when possible.
- As others have said, look on Google Maps
- Truck stops and rural stations as opposed to stations in urban areas are often more wide open.
- Don't be afraid to wait for an end pump that's easier to get into.
- Don't be afraid to have the copilot get out and back you up to get out.
* This post was edited 03/04/21 07:07am by valhalla360 *
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
kellem
Shenandoah valley,VA
Posted: 03/04/21 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Fill up before hooking up and fill up again after arriving at destination while out exploring.
ksbowman
Kansas
Posted: 03/04/21 06:42am Link  |  Quote  |  Print  |  Notify Moderator
I prefer one that is easy in and easy out on the right hand side of the road. That said I've had times I had to back in or back out. Doesn't matter I can back as easy as go forward.
 > Trailering
