RV.Net Open Roads Forum: Towing: Towing Harley and trailer
Search only in Towing
Open Roads Forum  >  Towing
 > Towing Harley and trailer
mikeandbrenda
Las Vegas
Posted: 03/04/21 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2012 Silverado Duramax Diesel Crew Cab 4WD 2500 HD Pulling a 6700LB Dry weight Travel Trailer loaded to around maybe 8000LB Loaded. I have a 14000LB Equillizer distribution hitch, the biggest they make, which was installed when I bought the trailer new, which they recommended. The truck has a towing weight of around 15000LB. It is all set up correctly now. Now I want to haul a Harley full touring motorcycle with auto ramp, motorcycle weighing 950LB and ramp weighing 300LB for a total of 1250 in bed of truck. The harley wouldn't be in back every time we camp, maybe once a year. Could I use airbags witch hitch to compensate for the occasional hauling of the harley?
QCMan
Independent Republic of Horry
Posted: 03/04/21 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Might help if you listed loaded trailer tongue weight and loaded truck weight and payload capacity for your truck. Then you can get some informed answers.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
jdc1
Rescue, Ca
Posted: 03/04/21 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
1200 + 1250 + 100 = 2,550. Plus your weight, passenger weight and other junk you toss in that truck (450+-). 3,000 pounds of stuff. You have a few hundred pounds to play with.
2oldman
NM
Posted: 03/04/21 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Or post in a more suitable forum.
Bishop area, California
Posted: 03/04/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
You do remember that air bags don’t increase capacity, they level the truck.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
JRscooby
Indepmo
Posted: 03/05/21 05:17am Link  |  Quote  |  Print  |  Notify Moderator
How long is the HD? Tailgate might be a issue bike or trailer.
As for weight, take your snot to scale, get your actual weights. Subtract actual from rear axle rating. 1300 lbs to spare?
mikeandbrenda
Las Vegas
Posted: 03/05/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I've had it loaded before but after loading the bike the rear of the truck sagged a little. It all works but I want to know if I can use air bags to readjust the rear end or to set distribution for both loads. It's just a hassle to readjust the hitch for bike and no bike.
The truck can handle a tongue weight of 2000LB. I've extended the the hitch 4" for ramp clearance which reduces the tongue 1/3rd for a tongue weight to approx. 1320LB.I don't have a scale for trailer tongue weight. I would estimate from 8% to 13% of weight of trailer, 640LB to 1040LBs. Airbags would have a 5000LB rating. I'm still researching rear axle rating.
* This post was edited 03/05/21 07:53am by mikeandbrenda *
valhalla360
No paticular place.
Posted: 03/05/21 08:45am Link  |  Quote  |  Print  |  Notify Moderator
An 8000lb (loaded) trailer should be up around 1000lb hitch weight. An extension on the truck hitch isn't explicitly called out for most calculators but it does affect it negatively. (640lb would be too low)
Add in 1250 for the bike and ramps.
Add in say 300lb for passengers
That's around 2550lb if you put nothing else in the truck with the vast majority going on the rear axle. What's the payload available on the truck?
Since you own the truck and the bike, best bet would be to load up and go to a CAT scale and find out ground truth rather than go off best guestimate ratings.
Airbags can level the load but they don't add payload capacity.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
BarneyS
S.E. Lower Michigan
Posted: 03/05/21 10:09am Link  |  Quote  |  Print  |  Notify Moderator
If it were me, I would add the bags, inflate to level the truck and leave the WD bars where they are.
Just like a 5th wheel, the bags are used to help raise the truck. The purpose of the WD remains the same - to put the weight lost from the front axle back where it belongs. There should be no change in your weight distribution if you simply raise the rear of the truck back to where it was normally when towing.
I wouldn't crank up too much on the 1400lb bars unless your trailer tongue is at least 6 or 8 inches tall on the frame members. Even 6 inches is a bit of a stretch for possible frame bending when the 1400lb bars are drawn up tight. If you use the bags to level your truck before hitching up, then you shouldn't have to change the bars much if at all.
Barney
Not towing now.
Cummins12V98
on the road
Posted: 03/05/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
"If it were me, I would add the bags, inflate to level the truck and leave the WD bars where they are."
Words of wiscom from our esteemed Moderator!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
