RV.Net Open Roads Forum: Truck Campers: Water Line help
 > Water Line help
The Clubhouse
SoCal
Posted: 03/04/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Rig: 98 Western Wilderness 9.6. New to me this is the maiden voyage. Had a toy hauler before but never winterized so unfamiliar with these pipes.
Issue: Water runs straight through to back drain pipe on left they are white. Can not figure out how to attach phone photo.
Occurred: When connecting city water to inlet water ran straight through. Connection is city bib -> regulator -> filter -> potable water hose to inlet. Could hear water gurgling when faucet opened. Tried putting water into storage tank and it held until water pump turned on then water ran out same drain. Does it need a cap of some kind?
Any ideas?
1 wife, 2 sons, 1 dog
billtex
RI
Posted: 03/04/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Kind of cryptic but try the water heater bypass. Sounds like its open.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
beemerphile1
Ohio
Posted: 03/04/21 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me like the low point drain, it should be closed by either a cap or valve. The valve may be inside.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
The Clubhouse
SoCal
Posted: 03/04/21 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I tried the valves before and after water heater in both directions and water still runs through with city hookup.
The Clubhouse
SoCal
Posted: 03/04/21 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have as best I could traced the water line and have no valves right before the outlet. There appear to be threads on the pipe so I am leaning towards a missing cap. I’m already at the campsite so I’ll have to follow up on this thought when I get back.
AnEv942
CA
Posted: 03/05/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Agree sounds like low point drain
Our low point drains/hot cold lines, terminate with female fittings, use simple 1/2" pvc pipe thread plugs. We do not have valves.
If there were any place near you, threaded cap or threaded coupling with plug should be easy to find.
Possibly if in park, store or maintenance facility or even other campers may have something. I had one disappear once so carry spares. Wouldnt hurt to ask Don't overtighten.
Our camper projects page
The Clubhouse
SoCal
Posted: 03/05/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Yes, other than color that location looks the same. My ends are different, naturally. With the drain port idea I have started googling that and I’m thinking I may go to the ball valve web suggestion.
Can you confirm that assuming it is an uncapped drain port that without the cap the water will just run through as my symptoms show?
billtex
RI
Posted: 03/05/21 10:58am Link  |  Quote  |  Print  |  Notify Moderator
We have owned several different campers. All had a shut-off valve in line before the end caps. Even our vintage AirStream.
In any case, stop at Home Depot and get a cap. Pretty standard.
midnightsadie
ohio
Posted: 03/05/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
if your in a cg now? go asl some body ,good way to make a new friend. p.s use valves. follow those pipes up ,see where they go.
AnEv942
CA
Posted: 03/06/21 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Mine have been coated, originaly one was white, the other red..
Yes if I remove or loosen plugs water in line will drain out, any pressure, pump or city, and it will just flow out drain.
 > Water Line help
