RV.Net Open Roads Forum: Fifth-Wheels: Changed the rear springs
 > Changed the rear springs
StirCrazy
Kamloops, BC, Canada
Posted: 03/06/21 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
StirCrazy wrote:
Cummins12V98 wrote:
" If not, then I'll have to install a pair of airbags."
IMHO bags should have been the first choice.
bags are a bandaid, springs are probably the best choice but also the most expensive. having had bags before I would buy timberans before I waisted money on bags again.
Steve
Not really. Two whimpy full length springs to hold things together and then the air bags do all the work. 9,750# on the rear tires. Nice ride loaded or not.
YES this ia Factory Rear Air Ride but the same applies with standard springs.
I bought airbags and put them on my old truck, worst money I ever spent. Timberins is what replaced them and was a much better ride.
Air bags or any other unit you can use wont raise your GVW so there only purpose is to make you level when loaded properly. but I guess what ever your happy with your happy with.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
plumber802
Vermont
Posted: 03/07/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
If you are over your payload allowance then you might need a bigger truck. I had Firestone Ride Rite air bags on our 2008 Chevy 2500 and liked them but the rig was well within payload specs.
Andy and Linda, St-Albans, Vermont.
Retired Union Pipe Fitter/Plumber. Former LEO 1994-2004.
Cummins12V98
on the road
Posted: 03/07/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
People who don't like the ride of their air bags when towing most likely have too much air in them. I only ran 30psi LOADED with 4,500# pin on my 11 DRW RAM and the ride was dramatically improved over stock.
Unloaded they make zero difference since you only should run 0-5 psi.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
TravelinDog
Nevada
Posted: 03/07/21 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
I like how people say you should go out and buy a bigger truck.
Not everyone can just go out and buy a $60,000+ truck to haul the 5er.
I have a 2500 Ram diesel very much like the OP. I will be looking to do the same thing as him because the truck will not be towing our future 5er 95% of the time.
TravelinDog
Nevada
Posted: 03/07/21 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
Are they the hollow rubber springs that make contact only when truck loaded? Like these?
garyp4951
TN
Posted: 03/07/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, but air bags ride a lot better, and work to supplement your existing springs.
I have a 2018 2500 and run 15psi in the air bags when towing. and zero when not, since they have the jounce bumper built in them.
Cummins12V98
on the road
Posted: 03/07/21 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Curious why you quoted me as nothing you just stated correlates with what I said???
StirCrazy
Posted: 03/08/21 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Steve
yup, there set up about an inch off the stop so unloaded you have a factory ride, but loaded they add support. I had them on my F250 when I bought my 5th and it road like a dreem, but I was overloaded so I did two trips and bought a newer 1 ton.
Steve
TravelinDog
Nevada
Posted: 03/08/21 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry about that, I meant to quote plumber802
* This post was edited 03/08/21 05:38pm by an administrator/moderator *
FlatBroke
CO/AZ
Posted: 03/09/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Have bags 5# empty, loaded without any changes it goes to 30#s. Now with my Bilstiens replacing my adjustable Ranchos, its hook and go. Perfect in every way.
Hitch Hiker
"08" 29.5 FKTG LS
