RV.Net Open Roads Forum: Travel Trailers: parking on hill
 > parking on hill
Seon
Lake Camanche, CA
Posted: 03/05/21 07:29am Link  |  Quote  |  Print  |  Notify Moderator
I'd put retaining wall blocks and back fill that area until level. Problem solved.
GrandpaKip
Flat Rock
Posted: 03/05/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
How far down the road? Are you going to use it meanwhile?
I ask because if it’s going to stay put for months at a time, I would definitely rethink how it’s sitting now. The OSB is going to fall apart, it looks like the passenger side rear tire is pushed in by the edge of the 4x4 and the driver side rear tire doesn’t hit much of the 4x4.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
trcothorn
NC
Posted: 03/05/21 08:46am Link  |  Quote  |  Print  |  Notify Moderator
We are planning on a retaining wall this year but probably not until fall. I know the osb won’t last long but I have several scrap pieces so that’s what I used to combat the tires sinking into the ground. I have the other side up on 2x10 boards to level it side to side. I’m thinking about just buying a railroad tie and anchor it behind the back tire for now. I wanted the trailer where it is because when I connect to the truck the truck tires are still on asphalt driveway. I can just about guarantee if I backed down the hill further where my truck was in the grass I would get stuck, even in 4lo. I’ve gotten stuck on flat wet grass in the ram 3500 because of the crappy stock tires.
ronharmless
The far side
Posted: 03/05/21 10:11am Link  |  Quote  |  Print  |  Notify Moderator
That wouldn't work for me, YOMV, but I'm not ready to let $25K go careening down the hill and start over from scratch. Because your asking other their opinion (from posted pictures no less) indicates to me you're not to comfortable with it. What's your gut telling you?
time2roll
Posted: 03/05/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
I would have bolted the wedge to the board for the rear tire instead of using the 4x4. More like the second picture. Skip the front wedge.
Adjust as you please next time you have it out. Fine for today. Eventual retaining wall would resolve everything.
675w Solar pictures back up
BarneyS
S.E. Lower Michigan
Posted: 03/05/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
He shouldn't screw down the rubber chocks that are behind the front axles because they have to be removed to get the trailer out. Otherwise he would have to just drive over them with the rear axle. They aren't going anywhere anyway unless a neighbor needs a pair. [emoticon]
Barney
Not towing now.
Quartzsite, AZ
Posted: 03/05/21 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
“I would dig a hole at the front and try to get the nose down as far as possible”
X2
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
phillyg
SWFL
Posted: 03/05/21 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
I used to park my Class A and C, and FW trailer on a similar angle for several years; no issues.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
trcothorn
NC
Posted: 03/05/21 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
After reading these comments, I am going to go ahead and start the pad project as soon as possible rather than waiting for a while. Now this opens up a lot of follow questions.
I would like to tackle this project myself, although I have never done anything like this. Without measuring at all my best guess is that I would need to to build a 3 side retaining wall that is approximately 2.5 to 3ft tall in the rear in order to get the trailer close to level. I have asked different people the best way to go about building the wall using lumber instead of blocks, and I got different opinions. One person told me to anchor 6x6 posts into the ground with concrete and build the walls with 2x6's. Another told me to use 6x6's to build the entire thing, using rebar to stake the base layer into the ground and attach the rest with spikes.
Youtube doesn't have a whole lot of examples of what I'm trying to accomplish, so if anybody has any knowledge of this please let me know.
Thank you for the help!
afidel
Cleveland
Posted: 03/05/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Used railroad ties, they're cheap and will last forever. I used 10" timberlok screws to tie the courses together and on the bottom 2 courses I used a 3/4 thick wall heavily galvanized pipe to secure them into the ground. To make the hole to drive the pipe I used a 7/8 spade bit with a 12" hex extension in my impact driver.
For a 3' high wall you're going to use what's known as a dead man system to keep it from leaning too much. I did a 2' wall without one and it's really leaning more than I like.
You'll also want to consider drainage, I used fist sized rocks (called 8's and 10's locally but this is regional) in the base but still put in a 5" perforated pipe to act as a french drain against the wall.
* This post was edited 03/05/21 08:26pm by afidel *
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
 > parking on hill
