BenK
SF BayArea
If the "Z" angle isn't matched close enough, the drive shaft will shake/vibrate/etc. What happens is that the end U-Joints get slightly out of phase and wear that way to become more and more prone to vibrate/shake
Betcha the tranny's rear mount has too much compliance and allows the "Z" angle to move around and once it starts to vibrate/shake/etc...it will continue until slowed down.
Also, 2 piece drive shafts with a center bearing/bushing has been known to have this on occasion after many miles have worn the center bearing/carrier
-Ben Picture of my rig
BobsYourUncle
Calgary Alberta Canada
goducks10 wrote: Shake shake shake, shake shake shake
Shake your Chevy, shake your Chevy
Oh, shake shake shake, shake shake shake
LMAO!! ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
I have never heard of Chevy shake either until I read this.
Soooo, what is next? Ford Fumble?
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
rhagfo
Portland, OR
Always a class action lawsuit!
Could be drive shaft angle, stuffed a 302 auto in a 64 Econoline, too much angle on a short shaft, vibration. Then lowered trans mount about 1” all better.
Could be bad U-Joints also, smart dealer would know great driveline shop in their area that could solve.
mooky stinks
Cicero,NY
Never had a “shake” per se but I did have a shudder with a 2015 6.2 w/ 8 speed. They ended up putting a converter in under warranty. It totally solved it. Truck was a rocket, shudder and all.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
covetsthesun
missouri
BobsYourUncle wrote: goducks10 wrote: Shake shake shake, shake shake shake
Soooo, what is next? Ford Fumble? ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
I knew it!!! I leave for a few hours and you guys ran with it!
Have to say... I'm LMAO too!! Apparently though, there is a lawsuit so be careful who you shake your Chevy at LOL!
BobsYourUncle
I actually had a shake in mine last fall, but a rear U joint totally fixed it.
mooky stinks
Cicero,NY
Settle down KC!
Hammerboy
Zeeland, MI
There's a lot of stuff online about the Chevy shake, just Google it. Anyway I brought my current truck to the dealer 3 times for vibration/shaking issues soon after I purchased it at around 3k miles. They ended up replacing the tires and doing a road force balance on it and that cured the problem.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
wintersun
Monterey
I received yet another notice from GM about the defective Takata air bag inflators which can kill people inside the cab if activated. It is for my 2011 Silverado 2500HD and still in 2021 GM is refusing to provide replacement parts.
I bought a 2018 Traverse and it is without a doubt the best vehicle I have owned in the past 50 years in every respect. More storage space than a Suburban and it gets 22 mpg around town and over 30 mpg on the highway. Smoother ride than I got with my Mercedes sedan. Controls are well placed and there is not an excessive reliance on the LED display to change settings like temp or fan speeds as with the Jeep Cherokee for example which was very frustrating.
The transmission is very smooth and I do not even feel the shifts. Fast acceleration which is critical where I live to be able to successfully get on the freeways with short onramps and so many other drivers busy with their fast food or texting.
Pre 2010 there were lubrication problems that led to short timing chain life but this has been fixed. I still change the oil every 5,000 miles with this engine just to be safe.
BB_TX
McKinney, Texas
Next thing you know we’ll have the
Ford flutter
Ram ruffle
Tundra totter
Titan tremor
Toyota twitter
Nissan niggle
