RV.Net Open Roads Forum: Tow Vehicles: What size jack and stands for f350
Search only in Tow Vehicles
 > What size jack and stands for f350
way2roll
Wilmington NC
Posted: 03/05/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Need to get a jack and stands for my new F350 6.7. We have a Harbor freight in town but the largest they have is 3t. Is that big enough? Doubt I'll use it much on the truck actually, more for my Son's Mercedes and Wife's CRV. But if I am going to get a new jack and stands, might as well get them big enough to handle the truck if need be.
BB_TX
McKinney, Texas
Posted: 03/05/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Unless you plan on jacking up more than one wheel at at time, that is plenty.
ACZL
UPstate,NY
Posted: 03/05/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I have the 3T as well from HF. Like above post said you should be fine. Could always get 2 more so you have 4 under the axles. If not check with NAPA no parts to see if they have higher ton jack stands. Do you have or know of any nearby semi truck/trailer shops? Could always check w/ them to see where they get theirs from.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
azdryheat
Tucson, AZ
Posted: 03/05/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Well, I weighed my dually at 8,800 pounds. Divide that by 4 and you have 2,200 at each corner. However my front axle weight is 4900 pounds so that's 2,450 at each end. 2 ton jacks at each corner would work fine, 3 ton much better.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
ferndaleflyer
everywhere
Posted: 03/05/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
I have the 3 ton from HF---that's 6000lbs---and they have performed fine for several years
Cummins12V98
on the road
Posted: 03/05/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
If you value your life stay the HE!! away from HF. Their stands already have a recall for failure. Look up US Made Jack Stands.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
JBarca
Radnor, Ohio, USA
Posted: 03/05/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Not sure what you are doing with the jack stands. There is a weight rating need, and then a stability need.
I looked today at Harbor Freight and seemed to stop selling the 6 ton and the 12 ton stands. Must be that lifts are getting more popular and the call for larger jack stands are not enough for them to sell them anymore.
Point in this, I have 4, 6 ton jack stands and 4, 12 ton jack stands from HF. I have had them for a long time. I go for stability along with weight rating. And how I use them, stability outweighs the weight rating most times.
Last winter I went all through my 2005 F350. Engine, frame rust, all of it. I used the 12 ton stands to reach high enough to get the stand up to the frame and the truck off the ground. See a few pics at the start of the project.
On our big camper, 10,000#, again when I have all 4 wheels off, I will use the 6 ton or the 12 ton, again for stability at the height.
The camper on the 6 ton stands during axle replacement.
The camper when doing frame repair using the 12 ton, I had them by this time.
The 3 ton, will hold 6,000# per pair, just the foot print is small. For what I do with them, the 3 ton stand has too small a foot print for me. It all depends on what you are doing with them at what height.
Hope this helps
John
* This post was edited 03/05/21 05:10pm by JBarca *
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
FishOnOne
The Great State of Texas
Posted: 03/05/21 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
For a Ford diesel truck 3 ton jack is fine for the rear end but for the front end it needs to be a minimum of 3.5 or greater
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
grizz272
frozen tundra, WI
Posted: 03/05/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I weigh my 2018 F350 when I bought it. It weigh 7980 total weight.
steering axle 4900
drive axle 3080
This was on the way home from the dealer.
PastorCharlie
NC
Posted: 03/05/21 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Harbor Freight recently had a problem with their jack stands and they had a recall on them. The replacements stands also had a problem and a second recall. I would make sure the ones they currently sell are safe before risking an accident.
They may be ok now but how can one be sure they will not fail until it is too late.?
I just bought over $150.00 of their products today but no jack stands.
