RV.Net Open Roads Forum: Technology Corner: Star Link
 > Star Link
Page of 6
DarkSkySeeker
Freestone, California
Posted: 03/05/21 09:56am Link  |  Quote  |  Print  |  Notify Moderator
justme wrote:
I could not use Hughes because of its high latency time that makes VPN run at modem speeds.
I might be over-stating this here, but I think Starlink is wrong to suggest the latency of its system is so good. The obstructions, beta downtime, and no satellites of the beta are nearly unacceptable.
Elon says space should be exciting. Starlink is exciting. First there is anticipation about the order, and now I have anticipation about more satellite 'fixing' the downtime issues.
There is something special about camping in an RV.
justme
Posted: 03/05/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Elon says space should be exciting. Starlink is exciting. First there is anticipation about the order, and now I have an anticipation about more satellite 'fixing' the downtime issues.
From what I see on Youtube of that shows latency, it is much better than Huges Net and would be OK for VPN. That is the difference between low and high orbit satellites. I measure Hughes which was over 150ms and Starlink was below 50ms.
DarkSkySeeker
Posted: 03/05/21 10:30am Link  |  Quote  |  Print  |  Notify Moderator
The latency becomes infinite during the downtimes I've mentioned. If the application you're using has a long timeout, you're fine.
sch911
Rochester Hills, MI
Posted: 03/05/21 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Latency is not an issue, period.
You must be an astronomer, or at least a wannabe one.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
Merrykalia
Appalachian (apple at chun) Mtn in the GREAT SW Va
Posted: 03/05/21 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
One of our local school systems are using it to extend internet services to some of their students who live in very rural, mountainous areas of our county. According to our technology director, it's working well. These are residences that don't move, so...
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
time2roll
Posted: 03/05/21 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Only about 8% of the satellites have been launched. Also the satellites are getting improvements as they go. Current situation will improve.
675w Solar pictures back up
time2roll
Posted: 03/05/21 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
The incredible speeds shown on the Youtube videos occurs when you are standing right next to the Starlink router. In my home, the router is 30 feet away and the signal passes through the floor of my living room. In my case, this cuts the bandwidth down from 100 Mbps to about 40 Mbps.
Is there no ethernet connection to get through obstructions?
1492
Arlington, VA
Posted: 03/05/21 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
I entered my name on the Starlink website way back last year. Then in early February, I received an email stating I could order a unit...
Good info. I also received my invite in late February to order Starlink, but holding off as I didn't think they had enough satellites to cover Washington, DC yet? Looks like we're at a similar latitude? May actually work in my area.
1492
Arlington, VA
Posted: 03/05/21 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
May not be for an internet user, but latency is a big concern for businesses. Amazon has said their research indicates they lose $160 million in sales annually for every 100 milliseconds (0.1 sec) of latency. The reason Amazon AWS is so focused on keeping it to a minimum.
time2roll
Posted: 03/05/21 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Compared to what? The Federal incentives are to cover the many rural people operating at dialup speeds or no access. This has to be a vast improvement.
Page of 6
 > Star Link
