RV.Net Open Roads Forum: Class A Motorhomes: Tire pressure and temperature recommendations
 > Tire pressure and temperature recommendations
beaubeau
Posted: 03/06/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Been a looooong time since we have had a trip to take, and now it's upon us!
I can't remember what I last decided about tire pressure.
We have a 2008 Allegro QDB. It's got 4 tires on 1 axle in the back.
I have all 6 tires set at 95PSI. How does that sound?
Also, I have installed a TPMS which monitors temperature.
What is a too-high tire temperature?
Thanks!
Chip & Nancy (and our 3 Shelties and 3 Cavaliers). 2008 Allegro Open Road Freightliner.
Ed C
Cape Cod, MA
Posted: 03/06/21 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
You need to know the weight...at each corner or at least each axle. Then you can check the tire manufacture's chart for those weights. If the tire pressures are right the temperature doesn't matter unless it changes drastically
Ed/Jeanie & Slade the GSD
2017 Entegra Aspire 42 RBQ/ Sierra Crew
Monterey, California
Posted: 03/06/21 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
What do the MH and tire manufacturers recommend?
haste maker
alabama
Posted: 03/06/21 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2007 Allergo 32BA and I run 95 psi in all the tires, and my gross weight is 18,000 lbs.
Retried Teamster
2007 Allergo
FloridaRosebud
Melbourne
Posted: 03/06/21 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
My MH weighs 19,000 lbs loaded, and I run 80psi in the front and 85psi in the rears. Based on both the Toyo and Michelin tire tables and the true weight of the MH.
Al
way2roll
Wilmington NC
Posted: 03/07/21 05:52am Link  |  Quote  |  Print  |  Notify Moderator
I would add that it needs weighed while loaded for travel.
beaubeau
Posted: 03/07/21 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone. I don’t see a way to get it weighed before I drive it, but the idea makes me want to pull into a scale pretty quickly.
JRscooby
Indepmo
Posted: 03/07/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Have bought tires for millions of miles. Over inflated will make it ride rough. And might have a little affect on handling. Under inflated will ruin a tire in a short distance.
Assuming you have a good compressor I would air up to max sidewall, stop by Cat on your way first day. Then after tires cool, and before next travel day adjust to chart.
Executive
Posted: 03/07/21 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Any Pilot/Flying J will have a scale. DON'T BE INTIMIDATED! THEY ARE THERE AND WILL HELP YOU! Pull onto the scale, placing each axle on each scale. Put it in neutral and release the parking brake. There is a microphone to talk to the cashier. Tell them you're an RV and want a weight ticket. They will tell you when they are through. Takes about 30 seconds. Pull off the scale and go inside for your weight ticket. Adjust your tire pressure as per mfg recommendations.....four corner weighing is best but it's more expensive and harder to find someone who will do it. Axle weighing is next best and will give you enough info to properly air your tires. Altitude and temperature will also affect PSI in your tires so adjust for that if traveling. I set my PSI twice a year (summer and winter) and rely on my TPMS while traveling.....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
beaubeau
Posted: 03/07/21 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the help! This trip does have a dozen or so miles on an interstate so I’ll be looking for a scale.
