RV.Net Open Roads Forum: Towing: disc brake delay
Search only in Towing
Open Roads Forum  >  Towing
 > disc brake delay
ford truck guy
Pennsylvania
Posted: 03/08/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
I had Morryde install the discs on my new Redwood when they did the IS.
I had nothing but problems with the system, Brian and Morryde was an awesome help, but his hands were tied for a good bit..
First Kodiak blamed Ford... Ford said they had nothing to do with it, My local tech was telling me he though it was the Hydrastar...
I took it to the tech and Morryde had them change the calipers and all the brake lines thinking I had a hydraulic issue, that didnt work... finally my tech told me he really thought it was the Hydrastar, so we pulled that off and replaced it with a Brakerite.. the problem went away ! We sent the Hydrastar back for evaulation, and received a check in full for the replacement and labor.
ENd of the story was it was the Hydrastar all along, and the discs are freakin awesome with the brakerite..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
lenr
Indianapolis, IN
Posted: 03/08/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Titan = BrakeRite. I am very happy with my Titan BrakeRite connected to a Prodigy P3. Others (my thread again) are very happy with a similar setup using a Ford controller set up to Med or High aggressiveness.
time2roll
Posted: 03/08/21 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Could have been defective in some way. My Hydrastar has been perfect.
The new trailer should have a warranty. The wildcard is the dealer expertise to find the issue.
675w Solar pictures back up
Edd505
Elephant Butte, NM
Posted: 03/08/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
I did my own install with a kit from Disc Kit and have had no issues. Their kit includes wiring, brake lines, pump and everything you need to include clips to secure the lines, the instructions are very clear as to what needs done. The only thing you need is grease & brake fluid.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
carolinaboy50
Louisiana
Posted: 05/30/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Problem fixed!! It turns out the problem was air in the FW brake lines. After bleeding the brakes, they now work fine. It took a long time to finally track down the problems because the RV dealer here in Hammond claimed they had bled the brakes earlier. so I looked for other fixes. They must have not done so or did not do it correctly.
Thanks for all of the replies.
Cummins12V98
on the road
Posted: 05/30/21 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Perfect example of why you should start with the basics.
My Motorcycle wouldn't start. A friend asked if I checked the battery connections. I said previous owner had recently installed a new battery. He gave me the LOOK. I checked and sure enough the bolts were loose.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
 > disc brake delay
