RV.Net Open Roads Forum: Towing: disc brake delay
Search only in Towing
Open Roads Forum  >  Towing
 > disc brake delay
carolinaboy50
Louisiana
Posted: 03/07/21 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased a new Beacon FW with Hydrastar disc brakes. There is a 2 to 3 second delay between applying the brakes and the trailer brakes engaging. I pull with a 2018 F-350 DRW with the brake controller set to EOH with a gain of 9. I know some trucks need a HCA cam added, but Hydrastar says the 2018 F-350 does not. Anyone seen this before? How did you correct it?
Monterey, California
Posted: 03/07/21 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Two to three second delay is completely unacceptable. A gain of nine is unacceptable too.
time2roll
Posted: 03/07/21 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have a hydrastar pump as they are supposed to be one best with minimum delay. I have a Prodigy P3 controller and have not really noticed any delay on mine. P3 has a boost function to have the brakes come on a bit stronger right at the beginning. Not sure if the Ford controller has a similar option.
I would suggest bleeding the brakes as my only suggestion. Although probably a long shot on a new trailer. Process is a bit tedious due to the small reservoir on these pumps.
675w Solar pictures back up
Cummins12V98
on the road
Posted: 03/07/21 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
I concur, the factory does not always do a good job of bleeding the lines.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Edd505
Elephant Butte, NM
Posted: 03/07/21 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Controller at 9, you have a problem. My drum brakes were 9 and I installed disks and now run 4.5. There is another setting on the brakes in the F350 beside the gain or EOH. I would have to look in the manual or play with the control but it lets you select low/med/high for brake effort.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
lenr
Indianapolis, IN
Posted: 03/07/21 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
All disc brake actuators have some delay while they build pressure. Hydrastar is supposed to be one of the quickest. But an additional problem is that they all have a voltage level below which they do nothing. Google for my thread "Disappointed in Disc Brakes." https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29930221.cfm
I found my main problem to be turn on voltage with light braking. Because my 2012 F-350 did not have the "Low/Med/High" setting I had to resort to a Prodigy P3 to get the actuator to start working on light braking. The "Low/Med/High" setting, as I understand it, determines how aggressive the voltage back to the trailer is on light braking. I would try High to see how it affets things. After the brakes are set in, I would be surprised if a 9 setting didn't lock up the brakes.
bluefishgary
Middle River,MD
Posted: 03/08/21 04:28am Link  |  Quote  |  Print  |  Notify Moderator
I also have disks brakes,with the Hydrastar actuator. If I was to compare to the drum brakes it is night and day better.
My trailer is a 3 axle,had mine installed at Moride in Elkhart.
Make sure that the power line fron battery is big enough for the
Run to actuator.Brake fluid full.Bleeding system. Ground wire bigger.
I have a 19 Ford factory BC worked great. OEM brakes self adjustable and had 25,000 miles on OEM there was not much left on the shoes.
Now I only have 1800 miles so far but perfect so far.if mine has delay I can knot tell yet.
2019 Ford DRW C/C
2017 Vintage with living quarters 44'3 Axle
I caught a fish once -it was fun
lenr
Indianapolis, IN
Posted: 03/08/21 06:27am Link  |  Quote  |  Print  |  Notify Moderator
By setting my P3 to the highest level of initial boost, likely similar to the Ford high setting, it gets the actuator running on light braking. Then as I increase brake petal pressure the trailer braking effect comes on quickly. I had to switch from a Dexter to a Titan actuator for a lower start up voltage as my thread describes.
lenr
Indianapolis, IN
Posted: 03/08/21 07:48am Link  |  Quote  |  Print  |  Notify Moderator
This is the second thread about troubles with disc brakes on a Vanleigh trailer--the last one was with a Chevy I think. Anyway, the moral from that thread was that the factory wasn't much help blaming problems on the truck. I would try to get with someone from Hydrastar or a service shop with Hydrastar experience. Although Hydrastar claims to be fast I couldn't get factory support to confirm a low startup voltage. So, I went with Titan because the startup voltage seemed to be the lowest of the 3 main manufacturers.
Cummins12V98
on the road
Posted: 03/08/21 08:46am Link  |  Quote  |  Print  |  Notify Moderator
I have the biggest HydraStar on my DRV and the same only with the "Marine" label on my Boat Trailer. Both are lightening fast!
As mentioned Grounding and supply wire size may need attention. BLEED those lines!!! Keep actuator about 3/4" from top with proper brake fluid.
Proper lubrication of caliper slide pins along with mating surfaces is very important.
Their customer Service is great. I was loosing fluid with no leaks found and brake pads were not excessively wearing on my Boat Trailer. Finally I discovered the leak on the actuator. Called them and in minutes I had a tracking number for a replacement unit. Received the new unit within a couple days with a return label. No more fluid loss!
 > disc brake delay
