RV.Net Open Roads Forum: Fifth-Wheels: New Steps
 > New Steps
Bob Vaughn
Seffner, Fl.
Posted: 03/14/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
pismopete wrote:
I'm thinking about replacing the old steps on my 5th wheel with the Lippert Solid Step. My questions are 1. can I do it myself or do I need professional installation and 2.those of you that have installed the step are you happy with it? Thank you
Dont do it too many negatives to solid steps
bsbeedub
Gateway to the West
Posted: 03/14/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
We have a fifth wheel on order that comes with the Lippert solid step. Unfortunately, we will be unable to open these steps in our storage area because the units are close together. I’ll be buying the second generation MORryde that has the new hinge. This allows you to release the steps easily and it is similar to pulling the hinge pins out of an interior door. I’ll remove the steps and the bottom will easily slide under the unit next to me then I’ll just put the hinge pins back in. It isn’t near as convenient as the older style steps that pull out from underneath but it will work for me. At the camp site they’ll just be lowered per the design.
There is no opening for the old style steps or the Torklift Glowstep and I don’t want to cut into the skirt of a brand new trailer.
Bob & Susan
Shelby the Beagle June 8, 2005 - Dec. 24, 2016
2018 Ram 3500 6.4 HEMI, long bed, 4.10’s
2021 Coachman Chaparral Lite 25 RE
2011 Gulfstream Ameri-Lite 23BW - retired
2003 Dodge Ram 1500 - retired
shadows4
Kansas City, Mo
Posted: 03/14/21 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Times 3 on the Torklift!! 4 bolts and your done.
2003 4X4 F350,CC,SB,Lariat,7.3L diesel, 219,000 miles
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
enblethen
Moses Lake, WA
Posted: 03/14/21 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
The Torklift accordian steps are much different then the Lippert Solid Step.
The solid step is far more stable.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Hammerboy
Zeeland, MI
Posted: 03/14/21 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Torklift is very solid as they rest on the ground. Plus they dont have the limitations the solid step style has.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
enblethen
Moses Lake, WA
Posted: 03/14/21 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Solid Step has extendable feet to insure step has a solid bas making contact to the ground.
BarneyS
S.E. Lower Michigan
Posted: 03/15/21 07:45am Link  |  Quote  |  Print  |  Notify Moderator
As do the Torklift steps. They have two adjustable feet that make solid contact with the ground.
I am wondering why you stated that "The solid step is far more stable." referring to the Lippert steps. Have you owned, or used extensively, the Torklift steps? I have two of them on my trailer and can say they have NO movement up, down, or sideways when deployed and are a pleasure to use. They could not be any more stable than they are right now. I think your statement is a bit over the top.
Barney
Not towing now.
enblethen
Moses Lake, WA
Posted: 03/15/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I based my comments not as an owner but experience of my neighbors 5er.
The accordian style comment was from my experience numerous years ago.
goducks10
There
Posted: 03/15/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
I replaced the flip out steps on my TT with the Morryde version. We love em. However we have 2 doors on our TT. If you have just one door like most 5ers do then you you'll have many times that you can't open the steps out.
Rest ares being one, setting up on unlevel ground, tight storage areas, etc.
Ours are in the rear and if I deploy the solid steps before front to back leveling I could mess things up pretty good. Same with side to side which means no one gets in the 5er until it's level.
We have a 2nd door up front that still has the flip out steps so all the above is resolved.
The only downside for us and it's relatively minor is you need to adjust the feet almost every time you set up. Other than that they're quieter and definitely more solid than flip outs.
FWIW I would never have them on a single door RV.
work2much
On the Road
Posted: 03/15/21 10:43am Link  |  Quote  |  Print  |  Notify Moderator
What are all these limitations of solid steps? Aside from you can't be right up against something and use them?
Our new 5th wheel came with solid fold down steps. The feet adjust to ground imperfections. So far they have been great. Years ago we had a truck camper with the accordion style steps. Nowhere near as stable. Perhaps the tork lift accordion stairs are better than what we had but we have no complaints on the solid steps and wouldn't hesitate to add them to a camper that doesn't have them.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
 > New Steps
