RV.Net Open Roads Forum: Truck Campers: Now the water heater is leaking?
 > Now the water heater is leaking?
The Clubhouse
SoCal
Posted: 03/10/21 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
I am back home but trying to get my water lines working. I installed 2 new 1/2” valves. When I connected the first and closed it after running city water for a short while the water started draining out of the other drain, assuming hot water. I turned off the city and let the water stop draining then installed the 2nd 1/2” valve. I turned the city water back on and rather quickly noticed water coming out from the water heater area. Upon closer inspection I could see a stream shooting out from the cooler type insulation. I shut off the city water and opened both valves to drain the water. Not sure what if anything I did wrong. Any thoughts on what happened?
1 wife, 2 sons, 1 dog
billtex
RI
Posted: 03/10/21 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Kind of a cryptic post. We need the story from the beginning...
I’ll take a shot; is the pressure valve closed?
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
JimK-NY
NY
Posted: 03/10/21 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
I am with billtex. Your post makes little sense. Where and why did you install valves? What "drain" was the water leaking from? It also appears you had water coming out of the "cooler type insulation". I have no idea what that means. I thought the water was leaking from the hot side. What cooler?
BurbMan
Noblesville, IN
Posted: 03/10/21 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
I believe the "cooler type insulation" refers to the styrofoam jacket around the HWH. But I agree with Billtex, we need to rewind the story and understand what valves were installed where and why and to fix what problem.
SOLD: 2002 Lance 811 Slide-In Camper
2002 Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
d3500ram
Colorado
Posted: 03/10/21 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
When I did plumbing work on my last camper to add an isolation valve at the city water inlet, it was not tightened all the way. Water under pressure will come out at a decent rate!! Quickest dash tot he spigot I ever did!
NorthStar uses those "flair-it" type connection and if you don't get them seated tight, it will leak.
My guess is that OP needs to re-check the connections.
With respect to "a stream shooting out from the cooler type insulation"... I agree with others that might be the water heater... and if water is coming from behind it, then I hope OP did not compromise the connection inside it at the heater itself when doing the work.
Buzzcut1
Norcal
Posted: 03/10/21 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
guys look down a few topics to his post "Water Line Help"
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Old-Biscuit
Verde Valley
Posted: 03/10/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Water Heater was NOT properly drained/winterized and now tank is leaking cause it split
Brand/Model of water heater??
US NAVY------USS Decatur DDG31
The Clubhouse
SoCal
Posted: 03/10/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Apologies, I didn’t want to continue the previous post as with all the help the problem was solved and now there is this new problem. But completely understand how it’s missing pieces of the story without that context.
The new valves went on the low point drains. Right and left. Once I sealed up the system water and turned on city water within a few minutes it started streaming out of yes I believe it is the hot water heater but not at an obvious coupling, valve, or visible connection point. As you can imagine it’s hard to see back there. I’m guessing it is moving out of my realm of troubleshooting but wanted to tap the obvious experience of other campers to see if they had any ideas. Thanks for listening I hope that provides more clarity to the request.
Old-Biscuit
Verde Valley
Posted: 03/10/21 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
There are only 2 connections on backside of WH Tank
Cold Inlet at bottom of tank
Hot outlet at top of tank
No leaking from those connections then that only leaves the TANK
Pinholes/cracks/split
*unless it is an Atwood gas/electric then the electric element is on backside bottom center under a protective cover...gasket could be leaking
Outside compartment is 'sealed' from inside so leaks out there from water supply would not leak inside the RV
T&P Relief Valve, drain plug...possibly combustion/exhaust chamber
Flute Man
Payson, Arizona
Posted: 03/10/21 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
you need to get into it a little deeper and find out exactly where the waters coming from. Could be the tank, connection or a line.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
