RV.Net Open Roads Forum: Travel Trailers: Cleaning Fresh water tank and water heater
 > Cleaning Fresh water tank and water heater
wopachop
Who run bartertown
Posted: 03/11/21 11:27am Link  |  Quote  |  Print  |  Notify Moderator
If it's been awhile then definitely drain the water heater. Replace the anode rod if your model uses one.
RickLight
Washington
Posted: 03/11/21 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
And flush! Maybe even descale it.
https://youtu.be/TL7AtXJYNcc
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
StirCrazy
Kamloops, BC, Canada
Posted: 03/11/21 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
I used to use bleach, now I just use captian Phab purge tank cleaner. works great, and no massive rincing to get the extra bleach flavor out.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Flapper
Minnesota
Posted: 03/11/21 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
Most sources note a minimum of 6 hrs for 1/4 cup to 15 gal. You can speed it up by going to 1/2 cup for 3 hrs. Do NOT do more. Gotta give the bleach time to kill whatever it is gonna kill.
You can just run the faucets to flush the water heater, but it takes forever, since the fresh is slowly diluting gallons of bleach water in the heater. Much faster to pull the plug, and drain all the bleach water, then refill. Then all you have to worry about is the much lesser amount actually in the lines.
Yes, the concentration is low enough, it will not hurt grass or any other surface you dump it on.
Almost all city water is treated so that most of the chlorine is used up by the time it gets to your tap. There may be a little, but not enough to do any sanitizing on its own.
2012 F150 Eco, 4x4, SCrew, Max Tow, HD Payload
2017 Grand Design Imagine 2670MK
mhsmith
Toledo
Posted: 03/12/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
I pretty much do as most here leave it sit for a day. I then used the pump to empty the FW tank allowing it to run into the gray and black tanks. I then add baking soda to the fresh tank and fill again. Pump this mixture thru until bleach smell lessens and can leave it in the system for use after that. Kinda have a problem wasting more water than needed. I may leave the water in the gray and black tanks for a couple days then empty them.
smokamoto
usa
Posted: 03/12/21 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
I added a tee & drain valve to my water heater, much easier to drain now!
Rover_Bill
NE. Ohio
Posted: 03/12/21 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Taffy.C wrote:
Thanks for those answers. One more question - Is it best to drain the water heater after the sanitization, or is it ok just to leave the faucet open and pump fresh water through until the bleach smell goes away?
Pumping fresh water into the tank will only keep diluting the sanitation bleach water and really purge it. IMO it's best to drain the tank completely and refill with fresh water.
Scottiemom
Posted: 03/13/21 05:10am Link  |  Quote  |  Print  |  Notify Moderator
Steve
I have looked for this product and cannot find it. I have found holding tank treatment but nothing that goes by this name. Can you provide a link. Thanks!
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
spoon059
Just north of D.C.
Posted: 03/13/21 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I open my low point drains and burp the pressure relief valve on my water heater, almost every trip. That completely drains the lines and water heater.
We did that after a year that my wife got sick in the beginning of the camping season and we ended up parking the camper for 6 months. We had gotten water at a campground with a well and ended up with sulphur smelling pipes and water heater. Had to bleach and run baking soda through the lines to clear up the smell.
Never again. Drain almost every trip.
2015 Ram CTD
2015 Jayco 29QBS
Lynnmor
Red Lion
Posted: 03/13/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
Scottiemom wrote:
Steve
Dale
Google: captain Phab purge tank cleaner
or click
I see nothing about the product killing bacteria, only removing scum that might support it. I would use bleach after using that product.
