RV.Net Open Roads Forum: Tech Issues: Can a generator get rained on?
 > Can a generator get rained on?
wildtoad
Blythewood, SC
Posted: 03/11/21 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Covers don’t cost a lot so why not use a cover when not in use - rain or shine. Essential? Probably not.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Mike134
Elgin, IL
Posted: 03/11/21 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
To answer your question we don't really know, but I'd put it under the table, toss a tarp over it etc.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
guidry
Texas Cajun
Posted: 03/11/21 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
My firefighter friends use those Honda’s in all weather without any problems
Posted: 03/11/21 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
This is my favorite quote:
soren wrote:
I use a Honda 2000, on a daily basis as a homebuilder. It runs eight hours a day, sitting in the mud, snow or on a gravel pile. It has spent days in the pouring rain, seen a few snow storms, and got peed on by a dog. After three years, the case is banged up a bit, it needs a tune-up and an oil change. As for a rain cover......seriously? Don't forget to knit a little sweater for it too....it's chilly out.
Lol, I think I remember that post!
Personal experience: virtually the only time we use our 6kw generator at home is when the power goes out. 90% of the time the power goes out it’s due to storms and the generator sits out away from the house (noise) in the weather. When camping with the little Honda, it runs in the rain too.
Professional experience: In my profession we run many generators daily for temp power during construction. All weather, rain, snow, have worked a lot in the desert as well, but 10 years in Seattle, if we didn’t run gennys in the rain, our guys would have to use hand tools 6 months out of the year.
You know it’s a miserable day out when someone is stationed at the genny re setting the GFI all afternoon!
Short story, it is perfectly acceptable and accepted to not only expose them to rain, but to use them in rain as well.
2017 Heartland Torque T29
wopachop
Who run bartertown
Posted: 03/11/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
If the outlets dont have any covers you could use pieces of tape. Same with the intake and exhaust if a sideways wind could blow some rain in there.
Posted: 03/11/21 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Generators come in 3 types for this
1[emoticon]pen Frame "Contractors" likely should be tarped
Enclosed, be they 2: Traditional generators (Think Generac 1000) or 3:Inverter are usually more or less water resistance..
A horizontal driving rain.. Not a good thing for any device.
Thunder Mountain
Lost in the Four Corners
Posted: 03/11/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like my pair of Honda 2000. Only difference is mine are about 15 years old. Only problem I've had is when the temps get down in the low teens and they are cold soaked over night. They are more a bit cranky especially when they have summer oil in them.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
dieseltruckdriver
Black Hills of SD
Posted: 03/11/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same experience with my pair of Honda 2000s. The only difference is mine are only 12 years old. They have spent many weekends running in the rain.
That is a big reason I recommend a Honda over a cheap brand. I chuckle to myself over people that will spend tens of thousands on an rv, then cheap out on a generator.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
KCFDCapt
At Home
Posted: 03/11/21 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
As a retired fire captain I have experience with Honda generators in wet conditions. Our light plants were based on a 1000 watt Honda generator with a flood light attached. We used them outside, inside, when ever and where ever needed. They stand in water, mud, at odd angles and get rained on. I have seen one hit with a full straight stream from a 1 3/4 nozzle and get knocked across the room. It quit running. We stood it up, fired it up and it never missed a beat. Water proof? I don't know. Fireman proof? Seems to be.
valhalla360
No paticular place.
Posted: 03/12/21 04:44am Link  |  Quote  |  Print  |  Notify Moderator
profdant139 wrote:
We just drape a tarp over it, and anchor the tarp with rocks. I'm not sure that rain would be harmful, but I don't want to take a chance.
You do need to make sure the air inlets and exhaust are clear. Exhaust in particular could start a tarp on fire, so a tarp would need to be supported well up above the unit.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
