RV.Net Open Roads Forum: Find cross pieces under metal roof to mount solar panel?
 > Find cross pieces under metal roof to mount solar panel?
Ramblin' Ralph
Central California Coast
Posted: 03/11/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to have someone install a second solar panel on the top of my 2001 Lance 845 TC. I installed the first one (see pic 1), but I'm too old to crawl around on the roof now. Is there some device or technique that I could use to find the cross pieces under the aluminum roof to attach the panel securely? For the first panel I got a drawing (see pic 2) from Lance that shows the roof structure. It's been 15 years, but I think I used it to find the cross pieces by measurement. I'd like to confirm this by a device/technique rather than drill tiny test holes.
Thanks,
Ralph
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Bilstein Shocks, TorkLift Stable Loads, 100 Ah LiFePo4, 225 watt solar
My RV Travels Webpage / Yearly Campsite Map / 715 Campsites / YouTube Videos /
Instagram
KansasKen
berryton, ks
Posted: 03/11/21 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
i used a zircon hd900 to find the square tubes under my roof. i borrowed a wallabot and it did not work.
2011 Host Everest Triple & F350 Crew DRW 4x4 Diesel (both loaded see profile)
bighatnohorse
Gig Harbor - Cave Creek
Posted: 03/12/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
In the event that you cannot find metal substructure I would submit for your consideration using well nuts.
They are inexpensive and you can fail-test them in your garage/work shop by installing them in 1/8-inch luan and attempting to pull them out.
They work.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
mr_andyj
Georgia
Posted: 03/12/21 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Wait for a morning where everything gets covered with dew. The metal frame of camper will have less water condensation on it than the insulated walls or roof and it will be obvious where the steel or aluminum frame is.
joerg68
St. Ingbert, Germany
Posted: 03/12/21 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Does that camper have an aluminum frame? If it is built like my 2001 Lance 915 was, it has a classic wood frame and an aluminum roof. There is a relatively solid layer of plywood under the aluminum.
You could remove the interior decoration of one of the roof vents; that is pretty easy to do and exposes the layering/construction of the roof.
Depending on the thickness of the plywood, you can bolt the solar panels directly to the roof with some short wood screws, without the need to find additional support.
Seal all holes / screw heads well, goes without saying.
You might also consider to mount an air dam of sorts in front of the panel, so the wind doesn't get underneath it while you drive.
okan-star
Nevada
Posted: 03/12/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
I`m sure its a wood frame , you've got all you need in the diagram from Lance .
Look inside the camper at the ceiling , the trim that runs side to side every 4 foot will give you a starting place to use the Lance layout ,open the vent over the bed and transfer from ceiling to roof , the trim is centered on a framing member , they are 3/4 " wide . The roof is foam core between 3/4" wide x 1 1/2 " framing W/ luon under the sheet aluminum roofing
I would defiantly not just attach to the aluminum and luon . I would defiantly look for framing to screw to .
I just put 4 more 100 watt panels on my Lance Legend 500 added to the 140 watt that I installed years ago .
Use this dicor tape under the panel mts and seal over the screws and around the mts with dicor self leveling caulk
* This post was edited 03/12/21 11:36am by okan-star *
Ramblin' Ralph
Posted: 03/12/21 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the tips. My camper definitely has a wood frame. I'll surely try okan-star's method that correlates the inside trim to the horizontal hidden framing members. Very useful to know the framing width, also.
Thanks,
Ralph
StirCrazy
Kamloops, BC, Canada
Posted: 03/12/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
not all. mine said there was but it turns out there wasnt. it only had plywood in the front bit.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
ticki2
NH
Posted: 03/12/21 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
If you feel comfortable that you hit the rafters with the one installed you can use it to measure from to fond the rafters for the new one using the diagram
'68 Avion C-11
'02 GMC DRW D/A flatbed
Bert the Welder
Van. Island
Posted: 03/15/21 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
I recently saw someone post they had doubled up the panel "L" mounting brackets so they now looked like "T"'s (basically took two L's and put them back to back). This doubled the contact surface with the roof. They then used the 3M VBM tape to attach the panels to the roof. Then Dicor over top. No screws and had no issues.
Unconventional, but something to consider given you aren't adding more roof holes and you can mount it anywhere on the roof.
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
